Guys with larger lifts, e-brake cable length. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Guys with larger lifts, e-brake cable length.
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-13-2006, 09:59 AM   #1
eagleno49
throbbing member
eagleno49's Avatar
What did you guys do to make your e-brake work. My cables are barely long enough and I think I might break something if i flex.
running like a raped ape
eagleno49 is offline   Reply With Quote
Unread 02-13-2006, 12:25 PM   #2
brossie
There is a relocation bracket out there. I forget who makes it, hopefully someone will jump in and say the name of it.
brossie is offline   Reply With Quote
Unread 02-13-2006, 04:42 PM   #3
eagleno49
throbbing member
eagleno49's Avatar
bump
bump
Unread 02-13-2006, 06:52 PM   #4
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Good luck on that one. Since my Dynatracs were installed I have not had an e-brake. the oem cables would not completly release causing the whole wheel assembly to get very hot. I'm looking into rigging something up myself using some aircraft cable that's available at my local hardware store.
Experience. It's what you get when you don't get what you want.
A beaver without a pelt is like a peacock without feathers.
Memberships: California Association Of 4WD Clubs - Friends Of The Rubicon - The Blue Ribbon Coalition
K6CKR
Originally Posted by Grape Ape
How many times have we told you . DON"T DUMP THE BODIES CLOSE TO YOUR HOME!!
HVACman is offline   Reply With Quote
Unread 02-13-2006, 06:56 PM   #5
method84
I would think something like that should come with the lift kit itself
method84 is offline   Reply With Quote
Unread 02-13-2006, 08:55 PM   #6
eagleno49
throbbing member
eagleno49's Avatar
I was thinking I could build a bracket that would drop the oem bracked down at an angle. I am handy with my welder but I don't like to reinvent the wheel. So if anyone has an idea.......
Unread 02-14-2006, 11:30 AM   #7
Rommel
Hmm, I need to do some work on my E-Brake anyway. Does anybody have a picture of exactly where it is located and know how to adjust it? Basically, since I've put on my 2" BB my E-Brake no longer holds on steep inclines. Thought maybe it just needed to be adjusted from wear but maybe the lift is affecting it?
Thanks.
-Romm
"A dreamy horse! This is my 4th jeep since I first drive 12 years ago. I just drive jeep, always..." - Red Bull China
Rommel is offline   Reply With Quote
Unread 02-14-2006, 02:22 PM   #8
Nickb1907
Thanks.
-Romm
dont have any pics, but if you follow the lines they come to a point where you can adjust them make it tighter or looser.
I got teraflex ones, but i just put in an 8.8 so they are for the conversion. dont know if they make them for the d35-d44
Nickb1907 is offline   Reply With Quote
