gurgling sound from the engine?? - JeepForum.com
post #1 of 6 Old 04-25-2004, 07:35 PM Thread Starter
TJdave
TJdave's Avatar
Anyone ever have a gurgling sound in their engine when they hit the gas?? I just started really noticing it since i started using my bikini top. I checked for error codes and my FSM says
"# 11 error: No crank reference signal detected during engine cranking. Intermittent loss of either camshaft or crankshaft position sensor. CKP sensor target windows have too much variation. "
any ideas??
1997 Green TJ
RE 3.5 SF Lift Kit w/ Rancho 9000 shocks
Currie AntiRock and HD steering,
KC daylighters, Warn Front bumper
and some
rock sliders all sitting on 33's
NRA Jeeper #9
Ham Radio Call: KI6KCU
TJdave is offline
post #2 of 6 Old 04-25-2004, 10:30 PM Thread Starter
TJdave
TJdave's Avatar
come on somebody has to know what might be the cause
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #3 of 6 Old 04-25-2004, 10:39 PM
AudioGuru
AudioGuru's Avatar
I'd say that your camshaft and/or crankshaft position sensors are malfunctioning. The engine's computer can't use the data that is or isn't being sent.
Don't lie. God said so.
AudioGuru is offline
post #4 of 6 Old 04-26-2004, 07:49 AM
jeeptoplesstx
jeeptoplesstx's Avatar
There is a little ribbon that comes out of the distributer cap and goes into the engine....that is the same code I was getting...and it was going so far as to not let the jeep start sometimes...go check that...follow the ribbon and it should have a little connector...mine was loose and would fall out completely once in a while which was keeping the jeep from running...hope that helps
2004 Jeep Wrangler Rubicon
jeeptoplesstx is offline
post #5 of 6 Old 04-27-2004, 12:38 PM Thread Starter
TJdave
TJdave's Avatar
I tried looking at the ribbon and it seems to be okay. Any other suggestions before i take it to the stealership??
1997 Green TJ
and some
NRA Jeeper #9
TJdave is offline
post #6 of 6 Old 04-27-2004, 02:06 PM
Dragonmaster
Dragonmaster's Avatar
Only time I've ever had a gurgling/water rushing sound was right before my heater core completely clogged in -20 weather.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
Rubicon radiator gurgling. NC4stroker TJ Wrangler Technical Forum 1 08-16-2008 10:20 AM
Gurgling Noise??? panathinaikos55 TJ Wrangler Technical Forum 1 04-06-2008 06:35 PM
Gurgling noise MZH29 TJ Wrangler Technical Forum 12 08-25-2007 08:27 AM
What does gurgling when decellerating mean? cygnus3978 TJ Wrangler Technical Forum 8 08-22-2005 08:08 PM
gurgling radiator? BNovak TJ Wrangler Technical Forum 7 06-22-2005 02:39 PM
