Guages and Radio doesn't work after radio install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Guages and Radio doesn't work after radio install
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-09-2009, 03:08 PM   #1
HoosierDaddyTJ
I installed an aftermarket CD player in an ammo box under my backseat after the stereo that came with the jeep got stolen. Now, not only does the CD player not work, my gauges also do not work. They worked perfectly before.
I'm positive that this is my fault in one way or another. What could I have done? I checked all of the fuses and double checked my wiring. It's all okay. The panel lights work and my warning lights still turn on. It runs fine, just no radio or gauges.
I know that electrical is a pain in the rump and makes about as much sense as paranormal activity or psychics. Please help me.
Anything worth doing is worth doing right.
I wave at other Jeeps and get my feelings hurt if they don't wave back.
99 TJ 4.0L ALL BLACK, 2 in RE BB and 32X10.50 Super Swamper TSL Radials
HoosierDaddyTJ is offline   Reply With Quote Quick reply to this message
Unread 04-13-2009, 11:19 PM   #2
HoosierDaddyTJ
Blah. . .
Just as I figured. No help.
Unread 04-14-2009, 11:41 PM   #3
bikerman02
Check the I.O.D fuse in the fuse box under the hood. Buddy of mine gauges and radio didn't work turned out to be that fuse. Sorry if ya already checked it but a lot of people forget the fuses under the hood.
bikerman02 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2009, 02:57 AM   #4
Jonny Jeep
Jonny Jeep's Avatar
Bikerman's right. It's fuse 20 (10A) in the under hood PDC.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
