Growl after front diff fluid change!
#31 | |
Do it right or not at all
![]() Join Date: Jan 2003
Nonya, either put your research where your mouth is or stop your yammering. Even the Blackstone oil analysis report I already gave you a link to above talks about the good test results from 75W-90 Mobil-1 in an axle.
YOU claimed there was stuff all over the web yet I didn't find it when I searched. If you want to continue claiming that, then YOU give us the links. Afterall, it was you who said "If you do some searching on the net its very common problem with m1 75-90". ![]()
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#32 |
I guess that answers everything...
#33 |
hey mean fish I thought you were sending me that rear wiper switch like 2 weeks ago
#34 | |
#35 |
yank that sucker before you leave. I could really use it
thanks Last edited by gtospeeding; 06-04-2007 at 04:12 PM.. |
#36 |
Well, I'm throwing in the towel. I pulled the rear diff cover, and had plenty of oil and no chipped teeth. I did, however, notice some metal shavings on the plug. I'm out of ideas, so it's up to the stealership figure it out.
#37 |
The dealership gave me their best guess today. They think it's bearings within the rear diff. Their recommendations, Option 1: If I want to, I can just have them replace the bearings, but if that doesn't fix it, I've wasted a lot of money on nothing. Option 2: I can have them overhaul the entire diff for $1800. Option 3: I can replace the entire rear end for a mere $1900 parts and labor. How bad am I getting gouged!?!
Originally, I had planned to have an Eaton E-Locker installed in the rear next spring, but with this little complication, it doesn't make sense to wait. I'm currently waiting for them to quote me the cost to fix the problem and install the E-Locker at the same time. We'll see how much they want gouge me for that. |
#38 |
Farm Wheeler
If you have to have differential work done run from that dealer. You can get it done for less and get quality work as well.
#39 |
Dont have the dealer do it unless its under warranty. That is too much money
01 TJ Sahara 4"short arm/rear gas&tire carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg 66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg 93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg 1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg 99 escort zx-2 my favorite lil gas "sipper" (who cares)lol USMC "Semper Fidelis" |
#40 |
Anywhere else in the country, I'd say you're right, and I wouldn't step foot anywhere near the dealership. Pinedale, WY is a small town 100 miles from the closest reasonable and capable mechanic. I have three mechanic options here in town. Mechanic #1 (and the guy I'd prefer to do the work) runs a shop that is primarily a tire shop, and doesn't have the tools to disassemble a differential. Mechanic #2 is the dealership. Mechanic #3 is a shop locally renown for royally screwing it's costomers. I had a friend take a subaru there, and they charged $60/hour labor on top of charging $700 for a part they admittedly purchased from Napa....a part that could be purchased directly from Napa for $300. No Thanks! So, unfortunately it's the dealership by default.
#41 |
for 1800 bucks you can nearly buy an axle with locker, chromos and your choice of locker and install it yourself
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System |
#42 | |
Id drive 100 miles every day to save a thousand dollars or more of my hard earned money. You should too unless you dont have secondary transportation or something. YOu could still save big bucks after the cost of a rental car
#43 |
What should it cost to have a shop rebuild a rear diff? I really don't have the setup to do it myself, so I'm stuck having someone else do it. If I do some calling around, what price range should I be looking at to have this done?
The other option would be to purchase a used rear end from a salvage yard, call in a favor or two, and swap the entire thing myself. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
