Growl after front diff fluid change!
#16 | ||
#17 |
Do it right or not at all
![]() Join Date: Jan 2003
Yep, well I ran Mobil-1 75W-90 and had NO worn out carrier bearings. In fact I just recalled I have been running it in my axles for probably 5-6 years now, I just don't use Mobil-1 in my engine. It just sounds like whoever set up your gears didn't know what they were doing. Plenty of JF members talk about their use of Mobil-1 gear lubes so it certainly isn't exactly responsible for an epedemic of bad bearings.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#18 |
it wasn't worn gears,it wore the carrier bearings.If you do some searching on the net its very common problem with m1 75-90.3 sets in my 99 until we realized it was the oil.Was very frustrating.Most people wouldn't know the bearings are bad until 75k or so,but i know the sounds and knew something was up.Like i said its common,i know all you m1 guys are gonna say bs but i wouldn't use it if came with Pamela Anderson.
#19 |
This may be too simple but did you possibly tighten the diff fill plug too tight causing it to hit something on the inside? I know people do it all the time with aftermarket covers which you may have. I'm sure with enough force you could do it to a stock cover.
#20 | |
#21 | |
#22 |
think what you want but its ture,the 75-140 ok but the 75-90 is complete garbage ask any good gear shop what they use.
#23 | |
#24 | |
#25 | |
#26 |
I just used Google and Yahoo to search for problems with Mobil-1 75W-90 and found NOTHING negative.
One of the many non-negative 'hits' was a Blackstone oil analysis of Mobil-1 75W-90 and it said the results were excellent... http://www.gm-trucks.com/forums/index.php?showtopic=4617 Nonya, I personally think you're full of crap on your groundless Mobil-1 75W-90 claims.
#27 |
funny how everyone is brain washed into m1 and other synthetic oils that are really garbage but like anything market hype sells it as true and good.look at the mean fishes post! brainwashed!
#28 | |
#29 |
#30 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
