Ground question - JeepForum.com
post #1 of 4 Old 05-19-2013, 10:43 PM Thread Starter
schwany01
Ground question
Just did the intake cowl, dont care about cold air intake stuff, so dont lecture me on that, did it for a snorkel for summer, going bake into engine bay for winter...
anyways i drilled through fire wall and they was a ground cable where i drilled, can move that ground to my battery, cant really find a better place to ground it too. thanks guys.
schwany01 is offline
post #2 of 4 Old 05-19-2013, 10:58 PM
JEK3
JEK3's Avatar
Your best bet would be to drill another hole in the firewall somewhere nearby and screw it into that. Almost all the ground points are through the body, and that's important for ignition noise suppression. If you go directly to the battery, you will probably start hearing your spark plugs through the radio. Worst case, though unlikely, would be that the noise interferes with the operation of the engine computer.
JEK3 is offline
post #3 of 4 Old 05-20-2013, 07:37 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Where does that gound go to? If it is the one for the hood then don't worry about it unless you really need that light. If something different I agree with JEK3
RnEmOvr is offline
post #4 of 4 Old 05-20-2013, 08:40 AM Thread Starter
schwany01
thanks guys look at it more today
