Groaning/Whining Noise When Turning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Groaning/Whining Noise When Turning
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 10-05-2009, 08:17 AM   #1
winstonk
I have this strange groaning/whining noise that appears when I am turning the Jeep (2004 Sahara) either to the left or right. Does not make any noise when driving straight. It is a loud noise. Have no idea what it could be. It is more noticeable when turning slowly. Any ideas what this could be? Thanks!
winstonk is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 08:18 AM   #2
heezy101
Power steering fluid is low
my $.02
'98 TJ, Rough Country Long Arms, Curry HD steering with Redneck Ram Hydro assist, RE 4.5" Springs, Bilstein 5100's, 15x8 Procomp 1079, 35x12.50 BFG KM2's, LOD Signature series rear bumper and tire carrier with lights, Super 35, 4.56's, Detroit TruTrack front, ARB rear, Viair Heavy Duty OBA
heezy101 is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 04:19 PM   #3
jabsTJ
Could be a bad wheel bearing as well if it seems to only make this noise while your rig is moving. If you still have the noise while sitting still x2 on the power steering fluid being low.
jabsTJ is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 04:54 PM   #4
slamtojackson
Does it sound like Chewbacca? Mine did that when turning. There is a rubber grommet where your steering shaft goes through the firewall. work your lubricant of choice between the steering shaft and this grommet. May not be what it is but I do know it is a very common issue for Jeep owners.
Edit - To say that if it is the grommet it is completely harmless. Many Jeep owners grow to know and love their Jeep Wookie.
slamtojackson is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 05:06 PM   #5
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I second the check power steering fluid level.
GOLENJEEPTJ is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 05:34 PM   #6
spyder6
Got that Toyota chit
spyder6's Avatar
2010
are you trying to push it past full lock? the PS pump could be straining if you're doing that
otherwise, check the fluid level
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 07:17 PM   #7
electrichead
x2 on this suggestion, had the same problem on my 98. Fixed with a shot of white lithium grease.
electrichead is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 12:53 AM   #8
RT8827
Last week, I bought an '04 TJ "X" and it has a similar problem... although it's a bit inconsistent. It groans during slow-speed turns (both L and R), but ONLY if I've been driving the Jeep for a while. No noise when driving straight, and the noise is louder on slower turns. If the Jeep has been sitting for an hour or two before I drive it, there is no noise during turns at any speed. The groans are loudest after I've been driving at freeway speed... after exiting, the groaning almost becomes a popping sound during a slow turn.
The PS fluid level is fine... I've checked it a few times. I've jacked up the front end and tried to 'rock' the wheels back/forth (checking for u-joint play), but they seem fine. The Jeep drives straight & true... no shimmies or wandering at any speed. Stock wheels & suspension (no lift... yet).
I will try the lithium lube on the steering wheel grommet (at the firewall), but it seems my symptoms are more than just a grommet needing lubrication. I sure hope I'm wrong. In the meantime, I'd welcome any ideas for other things I can/should inspect. Thx
Just like my Jeep hat says: "Life is good... do what you like, like what you do."
RT8827 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2010, 03:40 AM   #9
TheRealKTrain
Same story here, on my '97, but what gets me, is my P/S pump leaks, but the fluids are fine? I think my jeep might be crying
TheRealKTrain is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 03:53 PM   #10
comatose76
RT8827......I read your post and I think you might be driving my Jeep....but really. The description of your problen is the EXACT problem that I am having. Did you ever figure out what was causing it?
comatose76 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2011, 05:36 PM   #11
Therou
I think I may have the same issue here.
1997 TJ Emerald Green Pearl 4L 6Cyl 27X XXX KM
Green Jeep Club Member #190
NGJC #8
Canadian Jeep Club Member #15
Stock Jeep Member #55
www.therou.ca
Therou is offline   Reply With Quote Quick reply to this message
Unread 04-12-2011, 06:10 PM   #12
lancetkenyon
Tell your chic in the passenger seat to shut up. The Jeep will NOT tip over. I had that issue for a long time until I started leaving her home.
Flexes like a boneless hooker on muscle relaxers.
lancetkenyon is offline   Reply With Quote Quick reply to this message
Unread 02-02-2012, 09:05 PM   #13
TJcnm03
me too, me too... 04 tj x any one figure it out??
TJcnm03 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2012, 12:23 PM   #14
gene31572
2001 FSJ Cherokee
I just bought my 01 jeep cherokee and before i signed papers they told me this sound was a carrier bearing? sounded like a wheel bearing when turning during test drive but will have to see when i pick it up tomorrow..wish me luck
gene31572 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2012, 12:49 PM   #15
hulkboy
since nobody came back to update, does anyone know what this could be? i just bought an 06 with this exact problem. the noise is only noticeable after the jeep is good and warmed up.
I too gave the tires a good shaking and noticed no movement. it almost sounds as if there is some resistance somewhere. I'm about to lose it with this thing
hulkboy is offline   Reply With Quote Quick reply to this message
