-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   grinding when going into reverse? (http://www.jeepforum.com/forum/f9/grinding-when-going-into-reverse-682853/)
kloppk 01-30-2009 04:30 PM
Originally Posted by Dmcastino (Post 6469684)
There is nothing about what he said that would point to him having ANY problems with his clutch or anything else... Thats just how the Ax15 is since it doesn't have a synchroed reverse gear. Mine would still grind if I didn't do the trick I described earlier even when my clutch was a week old.....
The OP asked if it was a clutch or tranny problem.
Based on his symptoms of grinding it's a clutch problem.
I'm fully aware the AX doesn't have a reverse synchro. It's not necessary since you do not need to shift into reverse while rolling.
Grinding going into Reverse occurs when the clutch doesn't fully disengage.
If the clutch properly disengages the tranny input shaft will stop spinning.
Once it stops there will be NO grind. Period.
wmeyer116 01-30-2009 08:09 PM
well... as long as it isnt the tranny than im good. Thanks alot guys
The time now is 06:54 AM.
