Grinding sound from AC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Grinding sound from AC
Engo winches available at www.rockridge4wd.com! Free shippFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 12-11-2013, 11:34 AM   #1
drifts14x
Howdy everyone,
I just got a new noise in my Jeep.
When I first turn the A/C on, it sounds like grinding, but it is not a constant grinding sound, kind of like grind for a second, stop, grind, stop, and after about two minutes of operation, the noise stops entirely.
When the truck is warmed up, the noise does not come back during start up, only when the motor has been sitting. Any ideas?
drifts14x is offline   Reply With Quote
Unread 12-11-2013, 12:06 PM   #2
357transam
There's a better way....
357transam's Avatar
I have seen issues in the past where rust will build up on the clutch of the a/c compressor, so when activated, a grinding noise will occurr. More than likely though, the a/c compressor is on the way out.
357transam is offline   Reply With Quote
