Grinding "Pop" noise while making left hand turns - JeepForum.com
post #1 of 8 Old 01-23-2009, 07:17 PM Thread Starter
MikeUnlimited04
Ok, so for the last few weeks my Jeep has been making this relatively noticeable "popping" metal-on-metal noise while turning left. (It can best be described as a "pop" ..... "pop" "pop"..... "pop" during the duration of the turn.) The noise ONLY occurs while moving and turning left. It doesn't pop while turning right or while turning with the wheels while not moving.
It is about to drive me insane and I cannot pinpoint where it is coming from. I took some advice of a friend and topped of my power steering fluid and the problem persists. I am considering taking apart the whole setup tmrw to look for worn out or bent parts.
My entire steering system is STOCK.
I was just hoping if someone had a general idea of what the problem could be. I really dont know Jack about steering components so all advice is helpful!
Thanks! -Mike
United States Air Force F-15E Strike Eagle Crew Chief
Silver JEEP Club Member #36
MikeUnlimited04 is offline
post #2 of 8 Old 01-23-2009, 07:36 PM
rubidriver
Balljoints.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #3 of 8 Old 01-23-2009, 07:50 PM Thread Starter
MikeUnlimited04
Originally Posted by rubidriver View Post
Balljoints.
Thanks!
Can anyone else verify this as a possiblity>?
and what would be a good replacement?
post #4 of 8 Old 01-23-2009, 08:00 PM
williambmac
Sounds like you may have a bad axle joint. Jack the front end of your tj up and set it on jack stands. Then put it in neutral and cut the wheel to the left, rotate both front tires by hand and check for binding.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #5 of 8 Old 01-23-2009, 08:02 PM Thread Starter
MikeUnlimited04
Too late to do that tonight, but I will give it a try in the morning! Thanks!
post #6 of 8 Old 01-24-2009, 07:36 AM Thread Starter
MikeUnlimited04
I did what was recommended and I couldn't pinpoint the problem. I rotated both of the tires while turned left sitting on jack stands. I couldnt reproduce the noise. Any other ideas before I take it to the dealership?
post #7 of 8 Old 02-11-2009, 06:17 PM Thread Starter
MikeUnlimited04
Ok so I replaced both front U joints. The problem didnt go away.
I took it to a friends shop, Lifted it up and it turns out it was a bent piece of metal in the wheel well. stupid me. fixed and sounds fine now.
but while lifted up i saw my front pinion seal was leaking so I went ahead and had that fixed too.
Thanks for all the help!
post #8 of 8 Old 02-11-2009, 06:43 PM
Rubicon_TJ
Loose track bar bolts (on the axle end) usually "pop" during left hand turns. My TJ has done it before, and both my old XJ and my buddy's XJ have done that too.
Torquing the bolt back to spec fixed it, but after it recurred I finally put in a larger bolt and it quit for good.
You probably will also want to check the track bar nut on the frame bracket while you're at it.
EDIT: Glad you got it. I started my reply while your last post was on its way - got distracted and then hit the post button w/o rechacking the thread, so.... nevermind.
2003 Bright Silver Rubicon
285/70/17 Goodyear Kevlar MT/R's, OME, DIY bumpers/roll cage upgrades,
Champion beadlocks, 33Eng BellyUp w/CV shaft, JKS BL&MML
Rubicon_TJ is offline
Inline 6 making "ticking" noise when warm 06choppertj TJ Wrangler Technical Forum 18 09-07-2010 03:10 AM
"Clunk" noise when making a left turn. BloodThirsty TJ Wrangler Technical Forum 3 04-30-2009 12:44 PM
Jeep Making "Clanking" noise... CAPCDT388 TJ Wrangler Technical Forum 20 01-17-2009 02:31 PM
Front driver side brake is making a "pop" noise burchdog32 TJ Wrangler Technical Forum 1 06-14-2007 08:16 PM
Weird "grinding noise"... BuffaloYJ YJ Wrangler Technical Forum 4 09-22-2003 08:13 PM
