grind or relocate (rear shocks hit now) - JeepForum.com
post #1 of 10 Old 12-15-2011, 12:44 PM Thread Starter
mikesbeachhut
Since I rotated my pinion up I noticed my rear shock cans hit at full droop.Do I go TERAFLEX lower shock extenders or just grind off some of the spring perch.Ill probably lose some shock travel with the extenders but will it make much of a differance?
mikesbeachhut is offline
post #2 of 10 Old 12-15-2011, 12:51 PM
durango-bob
2006 WK
Both work. I have the extenders but the extra leverage that you get allowed me to rip off the mount one time.
durango-bob is offline
post #3 of 10 Old 12-15-2011, 01:00 PM
touched
Just grind them!
Rokmen TT,Savvy GTS, JKS BL MML,Orr-Fab sport Cage,Rock Hard front bumper,Body Armor side bars,Best rear bumper
Currie HD Steering , Savvy 4" lift, Fox shocks
touched is offline
post #4 of 10 Old 12-15-2011, 03:06 PM
shipsjeep1
I just ground mine twice last week and plan to do it again soon. My point is dont just do it barely enough... take the spring out of the way and grind it good (watch the brake line). I asked the same questioin about a week ago and chose to go with the cheapest....grind. Ther were a lot of replies on people extending and breaking factory mounts. Good luck!
shipsjeep1 is offline
post #5 of 10 Old 12-15-2011, 03:07 PM
DevilDogDoc
Flipping your shocks over might do it too.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 10 Old 12-15-2011, 03:14 PM
beartree
installed JKS shock extions on my TJ.
beartree is offline
post #7 of 10 Old 12-15-2011, 03:24 PM
2jhanna
Sorry for a quick hi-jack, but beartree, are those "centrifugal balancers" on your hub ? How well do they work ? Or just a dust shield ?
jhanna
denton county, tx
2jhanna is offline
post #8 of 10 Old 12-15-2011, 03:35 PM
beartree
Those are Centramatic wheel balancers. I have had them on my Rubicon since I brought it home from the dealer. The old MTRs looked like new ones except for less tread when I replaced the with 76,000 miles on them. I used to run them on my Kentworth back in the day when I owned my own truck.
beartree is offline
post #9 of 10 Old 12-16-2011, 03:10 PM
lupinsea
lupinsea's Avatar
Grind.
The shock extenders will rip off your shock mounts, eventually. Too much leverage.
And as someone said, it's handy if you take our your rear springs to do the grinding. But, IIRC, it may not be necessary.
Of course, I'd recommend doing the AEV / Nth Degree shock shifter kit. It does wonders for the handling/ride of the rear end of the TJ. I did my own by trying to reverse design the Nth kit. . . after doing that I FULLY recommend just getting the Nth kit. It'll save you boatloads of time. This is more involved than just cutting the spring perch but it'll give you a nice improvement in the ride of your TJ. No more back-end wiggle going over bumps and the rig feels more planted.
The SS mod is a step between running shocks in the stock location and doing the full frame-cut, long-travel shock mod.
- Jay
lupinsea is offline
post #10 of 10 Old 12-16-2011, 03:21 PM
Sgt.Fuzz
Shock extenders are a bad idea. Take a cutoff disk to the back of the spring perch and you're done.
My build:
Sgt.Fuzz is offline
Do I need to relocate my rear track bar bracket? dexetr30 TJ Wrangler Technical Forum 25 09-01-2014 11:00 PM
Rear Track bar and relocate bracket Benderff TJ Wrangler Technical Forum 6 05-24-2007 08:28 AM
Rear License Plate Relocate CarRamRod TJ Wrangler Technical Forum 3 11-07-2006 11:09 PM
Relocate rear shock? JN06TJS TJ Wrangler Technical Forum 15 10-13-2006 09:16 AM
simple but cheap way to relocate rear shocks? Muddeprived TJ Wrangler Technical Forum 13 03-09-2005 09:45 PM
