grill removal 98 tj - JeepForum.com
post #1 of 7 Old 12-17-2007, 06:37 AM Thread Starter
clyderains
grill removal 98 tj
need to know how to remove my front grill on my 98 tj. Thank you
clyderains is offline
post #2 of 7 Old 12-17-2007, 07:06 AM
Rocky529
Rocky529's Avatar
I'm pretty sure it is welded in.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 7 Old 12-17-2007, 07:23 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
If you have a/c,evacuate the a/c system.
Remove front crossmember cover
remove crossmember valance cover
remove cooling system redervoir
remove the bolts that secure the radiator and shroud to the grille panel
disconnect high and low pressure a/c lines
remove the radiator support rod to panel bolts
unplug electrical connectors to lights
remove fender to grille panel bolts
remove grille to frame mount bolt
detach the grille
simple huh
TheBoogieman is offline
post #4 of 7 Old 12-17-2007, 11:58 AM
BlueFlame
BlueFlame's Avatar
why would you have to dump the a/c? Sure looks to me like you can just unbolt everything and take the grill right off.
BlueFlame is offline
post #5 of 7 Old 12-17-2007, 12:15 PM
TheBoogieman
Just giving the repair manual removal instructions.I'm just being helpful,not pretending I've done it.
post #6 of 7 Old 12-17-2007, 02:43 PM
BlueFlame
BlueFlame's Avatar
gotcha. nor have I.
Service manuals can be funny though.
For example on 22RE yotas, the books says to drain and remove the radiator for an oil pump install. Not necessary. Not even necessary for a water pump change, but worth it on saved knuckles if nothing else... The book also says to remove the crossmember to drop the trans. Not necessary and in fact easier not to, since the xmember straps to the tranny jack much more securely than the trans itself. Seen lots of that sort of thing over the years.
post #7 of 7 Old 12-17-2007, 02:55 PM
JJs99TJ
Thats all I did when replacing the bashed in grille of my
'99 a couple years ago.
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
TJ grill removal MTDennis TJ Wrangler Technical Forum 4 12-20-2011 06:36 AM
Power locks and grill removal burg JK Wrangler Technical Forum 4 03-29-2009 02:49 PM
Front Grill Removal '05 TJ cmorra68 TJ Wrangler Technical Forum 2 11-03-2008 01:36 PM
TJ Grill Removal finsout TJ Wrangler Technical Forum 4 09-26-2008 12:23 PM
Front Grill Removal: How? rock2r TJ Wrangler Technical Forum 3 06-27-2005 07:50 AM
