Grill inserts. - JeepForum.com
post #1 of 7 Old 03-26-2009, 02:15 AM Thread Starter
Jrdicu
Jrdicu's Avatar
Grill inserts.
Can someone tell me the trick to taking out my grill inserts so that I don't break them... Thanks.
Black 2002 Sahara
BFG MT's, RE BB, K&N filters, Dual Factory tops.
Jrdicu is offline
post #2 of 7 Old 03-26-2009, 03:52 AM
04RedTJ
They should just pop out fairly easily. I usually get mine from the top and pull gently but firmly and they come on out. I do mine that way to clean up behind them.
04RedTJ is offline
post #3 of 7 Old 03-26-2009, 04:04 AM Thread Starter
Jrdicu
Jrdicu's Avatar
Thanks for your response.. I have tried every which way.. I will give it another shot.. Thanks again..
Black 2002 Sahara
Jrdicu is offline
post #4 of 7 Old 03-26-2009, 09:21 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
post a picture of what kind you have. mine are held in place by small screws.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 7 Old 03-26-2009, 09:57 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I've seen some held on with 3M tape also.
TheBoogieman is offline
post #6 of 7 Old 03-26-2009, 10:06 AM
Jason D
Open the hood and looke behind the grille. You'll see the little tabs that are holding them in.
Also, some have inserts inside the inserts. The second pic is basically the same insert, but with the extra bars in there.
When I took mine out, I couldn't avoid chipping the paint no matter how hard I tried.
2006 Jeep Wrangler Rubicon
Jason D is offline
post #7 of 7 Old 03-27-2009, 05:13 AM Thread Starter
Jrdicu
Jrdicu's Avatar
Mine are like the inserts in your first picture.. I'm off until Monday so I will have to look under the hood to see if I can find what is holding them in place..
Black 2002 Sahara
Jrdicu is offline
grill inserts mic6 TJ Wrangler Technical Forum 2 11-14-2006 10:48 AM
JK Grill Inserts Sahara GT JK Wrangler Technical Forum 3 11-13-2006 04:59 PM
Grill inserts RedSoxFan TJ Wrangler Technical Forum 4 03-29-2006 08:32 PM
Cleaning grill inserts. Knox TJ Wrangler Technical Forum 1 05-07-2005 11:40 PM
Grill Inserts trance_junkie TJ Wrangler Technical Forum 2 12-22-2004 11:53 AM
