Greasing front axle shaft during change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Greasing front axle shaft during change
Labor Day Sale at UCF!Gibson WK HEMI 3" Catback - 5 Day Special!Ruffstuff XJ Unirail Channel Reinforcement....
Unread 08-09-2015, 07:14 PM   #1
randysmith
Junior Member
I finally got around to installing my Superior Evolution front axle shafts but have a question.
How much grease should you put on the shaft where the seal runs and do you think lack of the grease would cause a seal failure?
Reason I ask is a had a little trouble with the passenger side and had to gently tap it the last 1/8" to 1/4" or so to get the damn hub on. I started researching it after I got it all bolted up and Stu Olsen's site shows him putting a bunch of grease on the shaft where the seal rides. Wonder if I messed up my seals by not greasing it up good, and whether I should tear it apart again to try to avert a seal replace by putting grease on that surface.
thx
randysmith is offline   Reply With Quote Quick reply to this message
Unread 08-09-2015, 07:24 PM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I wouldn't worry about it since there's plenty of gear lube on the backside of the seal. I will probably get criticized for this but as many times as I've removed and replaced my front axle shafts, I've never thought to grease the shaft where the inner seal rides. Never any leaks though. I can see where it would be a good idea though, I'll do that the next time I pull the front shafts. If I ever do again that is since I haven't had any axle shaft problems up front in years lol.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 08-09-2015, 08:19 PM   #3
randysmith
Junior Member
Alright!!!! I'll just watch the fluid level.
Thx for the reply.
Unread 08-09-2015, 08:37 PM   #4
Moabrubi
I only put grease there so it has less chance of messing up the seal while slipping it past. I don't know if it really makes a difference but it makes me feel warm and fuzzy inside so I do it.
Moabrubi is offline   Reply With Quote Quick reply to this message
Unread 08-09-2015, 10:54 PM   #5
randysmith
Junior Member
yeah, that's what I figured. First time at this and I'm learning as I go. Driver's side slid in no prob. Passenger needed a couple light taps to go the last smidge. I think it'll be okay but I have a regear coming up soon so even if there is a prob he can fix it when it's opened up.
Thx for reply.
