Grease Points - JeepForum.com
post #1 of 13 Old 09-14-2010, 07:54 PM Thread Starter
someschoolkid
Grease Points
How many total grease points are there for the steering linkage and tie rod ends? I just want to make sure that I don't miss any.
Also: Would grease should I use, and what grease should I be advised to stay away from?
someschoolkid is offline
post #2 of 13 Old 09-14-2010, 07:58 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Fill out your profile or specify which vehicle
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #3 of 13 Old 09-14-2010, 08:22 PM
Fropleyqk
Fropleyqk's Avatar
4 points
Fropleyqk is offline
post #4 of 13 Old 09-14-2010, 08:24 PM Thread Starter
someschoolkid
Done.
Any wise words of wisdom?
post #5 of 13 Old 09-14-2010, 08:46 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by fropleyquark View Post
4 points
I think mine had 7 when it was stock, now it has 27+-...
Knuckelhead is offline
post #6 of 13 Old 09-14-2010, 08:50 PM
daveg13try2
seven
daveg13try2 is offline
post #7 of 13 Old 09-14-2010, 10:01 PM Thread Starter
someschoolkid
Any ideas on what the best grease is? Or if there is no best... What some good ones / bad ones are?
post #8 of 13 Old 09-14-2010, 10:25 PM
mourerj
If you search it there is whole write up about it. I just found it like a week ago..
mourerj is offline
post #9 of 13 Old 09-14-2010, 10:29 PM
fishinjeeper
depending on your setup, my control arms have grease points. And I use Moly Grease. best stuff in my opinion
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #10 of 13 Old 09-15-2010, 05:56 AM
YellowX
YellowX's Avatar
Got Jeep Tech
Fred
JAFGJ
YellowX is offline
post #11 of 13 Old 09-15-2010, 08:00 AM
Fropleyqk
Fropleyqk's Avatar
Maybe Im brainfarting.
Steering: one at the left wheel, one at the right wheel, one at the Y joint and one at the pitmann arm. 4.
post #12 of 13 Old 09-15-2010, 08:04 AM
YellowX
YellowX's Avatar
Seven.
Upper yoke-to-steering knuckle balljoints (On both sides) - 2
Lower yoke-to-steering knuckle balljoints (On both sides) - 2
Drag link to tie-rod joint - 1
Pitman arm to drag link joint (left) - 1
Frame to track bar joint (right) - 1
=7
Fred
JAFGJ
YellowX is offline
post #13 of 13 Old 09-15-2010, 04:57 PM
Knuckelhead
AFSOC Retired
Originally Posted by YellowX View Post
Seven.
=7
You forgot about the 2 TRE's on the knuckles...
Grease Points? FourbyFour TJ Wrangler Technical Forum 6 11-13-2006 02:47 PM
where are all the grease points? NinjaTurlteSean TJ Wrangler Technical Forum 3 07-31-2006 08:30 PM
Grease Points? sky-raptor TJ Wrangler Technical Forum 3 07-31-2006 07:13 AM
Grease points Gritz TJ Wrangler Technical Forum 5 09-02-2004 08:19 PM
grease points ybs TJ Wrangler Technical Forum 2 05-31-2004 05:42 PM
