Grease fittings not releasing grease?? - JeepForum.com
post #1 of 4 Old 08-10-2007, 10:06 AM Thread Starter
Perspex
I just lubed the grease fittings on Jeep last week, but I noticed that the rubber things (sorry - dont know the correct name) that are behind the grease fittings just swelled up instead of letting old grease out. I took the fittings off and it looks like the grease was under pressure because 2x as much squirted out as I put in. I thought that the new grease was supposed to push out the old grease? How does it do this? Does it escape through a hole, or around the rubber seal or ??? Should I squeeze out all of the old stuff?
Perspex is offline
post #2 of 4 Old 08-10-2007, 10:34 AM
BNL TJ
Why do you want the old grease out? Aren't the 'rubber things' swelling up because they're filling up with grease? If you put too much grease in it's going to ooze out creating a mess. Take a rag and clean up any excess. I usually give about four pumps of the grease gun to each fitting after I go out wheeling.
BNL TJ is offline
post #3 of 4 Old 08-10-2007, 10:34 AM
Big-E
You don't have to blow grease out. As soon as it swells, that's enough.
Big-E
Louisiana
2000 Sport
Big-E is offline
post #4 of 4 Old 08-10-2007, 10:37 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
all your fittings on the jeep are this way, grease coming out is bad
RnEmOvr is offline
Grease Fittings truckin88 JK Wrangler Technical Forum 6 02-12-2009 06:56 PM
Grease Fittings smitkev2 YJ Wrangler Technical Forum 2 01-11-2009 06:28 PM
how many grease fittings on 09 cerbomark JK Wrangler Technical Forum 0 10-28-2008 03:46 PM
Grease Fittings JeepPirate TJ Wrangler Technical Forum 5 07-25-2007 11:43 AM
