grave lugnut/bolt problems... help! - JeepForum.com
post #1 of 15 Old 01-04-2004, 11:18 AM Thread Starter
Polaris
Polaris's Avatar
here's the problem... two lug nut bolts in the rear have stripped to the point that they can't thread a lugnut on... on top of that, there are two lugnuts in the front that WILL NOT budge, even with an impact wrench at +/- 110 psi. I've actually stripped them a bit trying to get them off with a tire iron in addition to the impact wrench. Is it possible to go on safely with one lugnut missing on a given tire? I'd assume not, but I might as well ask. thanks to all who respond!
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #2 of 15 Old 01-04-2004, 11:50 AM
igofshn
Locked @ both ends
igofshn's Avatar
If you are asking if you wheel will fall off, then no it won't. You can drive while missing 1 lug but you do need to replace it. The torque on your wheel will be off and the rim could possible become out of round or twisted.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 15 Old 01-04-2004, 01:59 PM
superman613
go to your local garage and they should have a special impact bit that will remove stipped lugs. We do it all the time for people. As for driving w/o one, don't!! Ive sen people snap their studs and completely lose a tire that way, not on a jeep but a similar 5 lug setup. Just go to a partsd store and get a new one for a dollar or so.
Superman
'98 Wrangler SE (yea that's right, four-banger)
5 speed tranny
33x12.50R15 MT/R's
15x8 Cragar Soft 8's
Explorer ProComp 2" suspension lift
1.75" BB lift on top of that
BL/MML coming soon to a Jeep near you!!
White Jeep Member #613
superman613 is offline
post #4 of 15 Old 01-04-2004, 02:00 PM
superman613
Also u might try heating it up wit a torch, I did that to get the locking lug off my spare cuz i didnt get the key for it.
Superman
5 speed tranny
33x12.50R15 MT/R's
post #5 of 15 Old 01-05-2004, 02:16 PM
3311jeep
If the lug nut edges are rounded you might try and hammer on a 12 point socket wrench on and hope that it works. If the lug nut stud is stripped and you are unable to get the nut off you have a couple options.
If it is on the rear you can remove the axle shaft with the wheel attached and grind off the back of the stud and drive the stud out from the rear. I am not sure what to do on the front.
Lastly, use alot of WD 40 or liquid wrench.
3311jeep is offline
post #6 of 15 Old 01-05-2004, 02:23 PM
3311jeep
If you can get the wheel and drum/disk off in you can drive out the wheel stud out of the axle/or front hub assembly and replace it with a new stud from any parts store.
3311jeep is offline
post #7 of 15 Old 01-05-2004, 04:56 PM
Scafone
Scafone's Avatar
I've gone through some lug nut headaches myself...I ended up drilling out the nut and replacing the stud of course. My problem was caused by someone putting the lugs on with an impact, which not only put them on too tight, but this weakens the POS aluminum cap on each nut. From now on, my studs get antisiezed and the nuts are never put on or taken off with an impact again.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline
post #8 of 15 Old 01-06-2004, 10:08 AM
runmanpkll
i have encountered a couple lugnuts on my rear that would not come off. a 1/2" breaker bar and some muscle will sheer off the lug stud. then once the other nuts & the wheel are off, take the brake drum off and drive whats left of the stud through the axle flange with a hammer. then fish a new stud in from behind and you can draw the stud into the hole using a washer & a flat nut. as you tighten the nut it will draw the new stud through.
runmanpkll is offline
post #9 of 15 Old 01-07-2004, 10:17 PM Thread Starter
Polaris
Polaris's Avatar
Thanks, all... I picked up some new lugs from 4wheel parts center (the stealership wanted $30 for 5!) and bolts from the stealership ($5.25 each for the rear). Guess I'll be using the torque wrench from now on
Polaris is offline
post #10 of 15 Old 01-07-2004, 10:25 PM
thecarman
Make sure the lugnut studs are not damaged either, that might be what's causing it. That or someone put them on crooked which could have damaged the studs.
1994 Jeep Wrangler 2.5L (White)
thecarman is offline
post #11 of 15 Old 10-04-2011, 04:02 PM
NakedCreekTJ
Okay I have a similar issue. A single lugnut us seized on mine. I've hit it with pb blaster and all, but the nut is totally stripped and what little bit is left it is.on so tight that I cannot loosen it. So any suggestions besides get a new lug nut.
___ ___
[l_,[____],
l---L - OllllllO-
( )_) ( )_)--)_)
NakedCreekTJ is offline
post #12 of 15 Old 10-04-2011, 07:45 PM
roundlitefan
Well, I guess no one can accuse you of not using the search function...
Twist the seized one until it comes off or snaps (not that hard to break a stud), then take your wheel off and drive the broken stud out through the back of the axle flange by hitting it with a hammer.
Put in a new one (a few bucks at any auto parts store) from the back, put your wheel back on, snug all your lug nuts in a star pattern, torque in a star pattern and go about your day.
roundlitefan is offline
post #13 of 15 Old 10-05-2011, 07:09 AM
dlysle
once you get your problem taken care of ditch the OEM lug nuts with the silly chrome caps and get some real ones. i got black ones from Q-tech and the work and look great!!
'You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you.' - Walt Disney, Animator, Film Producer
'four wheel drive only allows you to get stuck in more inaccessible places' - George Noll
dlysle is offline
post #14 of 15 Old 10-05-2011, 04:42 PM
Eric2000TJ
I am missing a lug up front; it was rounded so I used a striped bolt remover and needless to say it wasn't going back on. In back I had a lug sieze on and stip. I used the remover and it just kept on eatting it away. Finally it had to be drilled out. It ain't going to hurt. I do second dlysle and say get new ones, oem ones are dumb.
Eric2000TJ is offline
post #15 of 15 Old 10-05-2011, 08:45 PM
dlysle
i had my locking lug explode while trying to remove it, i ended up drilling out the stud, luckily it was on the wheel spacer not the hub so it was easy to replace. i no longer have locking lugs, now i have one piece black lugs i got from Q-tech
dlysle is offline
Grave Digger red headlights - DON'T LAUGH - My son would love it! Matt Graham YJ Wrangler Technical Forum 40 02-10-2008 04:59 PM
LugNut question bigblacktj TJ Wrangler Technical Forum 5 05-03-2006 06:05 AM
Lugnut key BobboTJ TJ Wrangler Technical Forum 7 12-14-2005 09:24 AM
Lugnut question silverstone01 TJ Wrangler Technical Forum 2 02-05-2005 08:35 PM
