got rear-ended this morning...where to go for parts? - JeepForum.com
post #1 of 3 Old 07-22-2010, 10:59 AM Thread Starter
Jayson44
so I got hit by some guy talking on his cell phone this morning. he hit me hard enough to smash the tank into the shocks and axle, and to not allow me to drive off.
but yeah, i have a dana 35 axle...I'm not sure if it's damaged enough to be replace, but I'm hoping so. the tub is tweaked a little in the back, and the bumper (aftermarket) is gonna need replacing as well. he hit me going probably 50-55...anyways, where do you go to replace parts like that? when progressive comes to do an inspection, will they replace all that? can I replace that stuff (gas tank, axle, tub) w/aftermarket parts?
if the axle needs to be replaced, are they gonna put another 35 back in there? I'd rather upgrade if I can...how should I go about taking care of this?
J.
98 TJ Sahara patrolling the FSRs above Denver...
Colorado Jeep Club Member #280
Jayson44 is offline
post #2 of 3 Old 07-22-2010, 11:13 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if the tank smashed into the diff, the frame is probably bent. and based on how fast he hit you, that is probably the case indeed. rear tub damage is hard to fix, unless you just patch over it with corner armor. i'm guessing it will be totalled.
don't expect progressive to cover aftermarket stuff or modified things, but definitely fight them on it to the best of your ability. the best thing you can do is take it to the Jeep dealership and get a full estimate for repairs. then tell the insurance thats whats needed to fix it...see if they'll cut you a check, then have a less expensive shop do whatever work you can't do, and spend the rest on a D44, corner armor, or whatever is needed to get the Jeep fixed and drivable again.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 3 Old 07-22-2010, 11:18 AM Thread Starter
Jayson44
I dont' know that it will be totaled, as it doesn't look that bad...he was driving a nissa altema, so he mostly hit from the bumper down...the tub just looked a little tweaked right below the tailgate...I didn't have my spare on the back, so it the tailgate seems fine.
but yeah, the tank was pushed up against the trackbar mount in the back as well as the shocks...
J.
Jayson44 is offline
wreck , damage , replacement , parts , tj , wrangler , axle , gas tank , rear bumper
Got Rear Ended dm33buckeyes TJ Wrangler Technical Forum 8 03-09-2010 04:56 PM
i just got rear ended joeyrossmiller YJ Wrangler Technical Forum 10 07-12-2009 01:53 PM
TJ Rear Ended 04tj TJ Wrangler Technical Forum 3 11-29-2008 06:59 PM
Rear Ended Twice Capinsano3 TJ Wrangler Technical Forum 7 10-28-2008 04:37 PM
Got Rear Ended joeyprice TJ Wrangler Technical Forum 9 05-21-2006 09:28 AM
