Got 'perculating' in the engine. (you know, bubbling sounds like a coffee pot?) - JeepForum.com
post #1 of 9 Old 04-26-2010, 12:34 PM Thread Starter
Erik T.
Pew Pew Vroom Vroom!
Erik T.'s Avatar
Can't figure it out.
I'm loosing coolant, somewhere.. its not dripping anywhere that I can tell. I refill about once a week. I went to change the oil, and under the oil cap was this... whitish jelly looking crud attached to the bottom. No idea what that was about. Oil was burnt black, this was about 6 months and 2500 miles past the last one.
But every time I stop and cut the engine off, I can hear it bubbling.. and it's coming from the engine block(or near it). Not the radiator.
Any ideas?
Oh, and if this is in relation to it, when I start my jeep a 'Check Gauges' light comes on and my Oil Pressure gauge is redlined, and slowly goes up as I accelerate. Once it hits the first mark, it doesn't really go anywhere.
I had the temp gauge replaced, but it continued to do it.
Atla.
- For those in the Trenches of Responsibility
Humorous, Witty, Slightly Obnoxious - Political and Social Commentary in a World Gone Mad.
New Post 10/16 -
Erik T. is offline
post #2 of 9 Old 04-26-2010, 12:37 PM
ChrisTJCO
Are you very sure it's not the radiator? I had a very similar problem in my last TJ and the issue was that the radiator cap was shot, so the fluid wasn't properly pressurized and it was literally boiling. After driving it, when I parked and got out, I could hear it "perculating" (as you said - that's exactly what it sounds like). If I were you, I'd go to AutoZone and buy a new radiator cap to make sure it's not that simple.
White-Out Jeep
Colorado Jeep Club Member #230
ChrisTJCO is offline
post #3 of 9 Old 04-26-2010, 12:45 PM Thread Starter
Erik T.
Erik T.'s Avatar
Radiator Cap? Never thought of that being an issue, I've taken if off and peeked inside to see if there was coolent. Than put it back on and the bubbling continued.
It's there any way to test the cap other than getting a new one?
Atla.
New Post 10/16 -
Erik T. is offline
post #4 of 9 Old 04-26-2010, 12:49 PM
ChrisTJCO
Not sure if there is a way to test the radiator cap. It's like 9 bucks from AutoZone or Checkers or wherever. I'd just buy a new one. If I remember correctly, when the jeep was doing it's "perculating," I could see it bubbling in the overflow tank. I might be wrong about that, but I think that's what I remember.
I'd just replace the cap and see - if it's the problem, you've fixed it for 10 bucks.
EDIT: Not even ten bucks - 4 bucks at your local O'Reilly/Checker's.
White-Out Jeep
post #5 of 9 Old 04-26-2010, 12:52 PM
OzarkOutdoors
Cracked head or busted gasket. The white jellyish crud is water in your oil.
Sorry
2008 Black JK Sahara Unlimited-Current Vehicle
325/70/17 Falken Wild Peak AT XD Addicts
2.5 inch BB, 1.25 RC Body Lift, Dual Top
s
OzarkOutdoors is offline
post #6 of 9 Old 04-26-2010, 12:54 PM
ChrisTJCO
Sorry
Ruh-roh. Much worse than my rad. cap diagnosis....
White-Out Jeep
post #7 of 9 Old 04-26-2010, 12:57 PM
EvilMonkey
Sounds like the white stuff on the cap was coolant mixed with oil. Not good. Zero oil pressure. Not good. Combine both and you may need to replace or rebuild the engine depending on the damage. I had that combination and now have a crate engine with a Mopar warranty
EvilMonkey is offline
post #8 of 9 Old 04-26-2010, 01:38 PM Thread Starter
Erik T.
Erik T.'s Avatar
Yay.
Reckon I'll just have my mechanic peek at it.
Atla.
New Post 10/16 -
Erik T. is offline
post #9 of 9 Old 04-27-2010, 01:46 PM
SurfnSnow
2010 JK Wrangler
This happened to me as well with the perculating. Recently, driving up a large grade (to Vegas and at 3k rpms) it perculated and burped coolant/fluid while on the road. The jeep never overheated and stayed right at 210 the entire drive from Vegas to Moab and all the way back. I changed the cap, added some fluid and all has been good. However with the white gunk you might have additional issues
SurfnSnow is offline
Engine sounds like a diesel...PLEASE HELP!! 92GTX YJ Wrangler Technical Forum 54 08-25-2010 12:19 PM
Sounds like a marble in the engine! A.B. TJ Wrangler Technical Forum 3 07-31-2007 12:37 PM
engine sounds 97cherokee JK Wrangler Technical Forum 8 01-07-2007 08:18 AM
My I-6 sounds like a Jet engine... NautOneFL TJ Wrangler Technical Forum 6 11-20-2006 02:13 PM
Sounds in my engine StainlesS_TJ TJ Wrangler Technical Forum 9 01-10-2002 06:13 PM
