Got our Jeep wet, Now it dies when we take off. :( - JeepForum.com
post #1 of 13 Old 08-16-2009, 11:06 AM Thread Starter
srtreat83
We have a 97 Jeep wrangler. Ok so in the offroad course park last weekend my husband and I went through some pretty deep water in which the little hill at the beginning kinda made the hood & front in dip into the water first. A few minutes later it started cutting out and died. It started back up and died as soon as we started to take off. Since then it will either not start at all or die after a few minutes of idling or die when you start to drive it. We have hair dryed the rotor and distributor cap ( not sure if that is the right name and hubby isnt here) and that seemed to help make it run longer. Whenever it doesn't start it turns over but doesnt start. No fuses are blown under the hood except the cig lighter. My husband is notorious for guessing at what is wrong and fixing 10 things that are perfectly fine before finding the real problem so I just thought I would try to see if anyone might know... Any ideas?
srtreat83 is offline
post #2 of 13 Old 08-16-2009, 01:00 PM
fromme
fromme's Avatar
1977 CJ7
Wish I knew what the problem is, but I don't go in deep water. Everytime I see someone do it they have either hydrolocked the engine or experience the same kind of thing you have described for months or years to come.
I'd start by using shop air to dry out all the harness connections and putting some dialectric grease on them. Then I'd do the same to the spark plug wire boots on the both ends. I am curious to know if water was ingested at the air filter box. Has he taken that off and inspected the filter and inlet tube? Could be a bigger problem than just some water at an electrical connection if so. How'd you get home?
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #3 of 13 Old 08-16-2009, 01:20 PM
justin102
Check the air filter box. You prob sucked some water into the intake. thats where I would start
"A jeep is like a fine woman, they both suck you dry of money"
justin102 is offline
post #4 of 13 Old 08-16-2009, 01:54 PM Thread Starter
srtreat83
We rode with a friend and pulled the jeep home on a trailer. We were, however, dumb enough to take one of our daily drivers to the offroad park. lol next time we will take a project vehicle we can tear the piss out of without worry. I do not think he has checked the air filter box. We will try these things out. Thanks
post #5 of 13 Old 08-16-2009, 06:17 PM
shaggy03TJ
sounds to me like sucked some water into the engine. I'd pull all the spark plugs crank the engine should push out some water if any in there might want to take flash light and look into spark plug hole maybe can see water before cranking. then either clean the spark plugs or change them along with the air filter. happened to a guy i use to off road with we had no tools though so instead i pulled him around in a corn field for an hr with his jeep in 4th gear until it cleared out the water from his engine thank god didn't hydro lock his engine.
shaggy03TJ is offline
post #6 of 13 Old 08-16-2009, 06:23 PM
rezhick
Spray wd 40 all over the distributor cap and plug wires it will dry out the electrical system.
rezhick is offline
post #7 of 13 Old 08-16-2009, 06:41 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you checked for water inside the distributor cap?...
Knuckelhead is offline
post #8 of 13 Old 08-16-2009, 08:56 PM
fromme
fromme's Avatar
1977 CJ7
Just because it's a project vehicle doesn't mean it won't suffer from the same problems. Lots of people take daily drivers wheeling, that wasn't the dumb part. Just stay out of the water.
Also, pull the intake tube off the throttle body and open the butterfly. Let us know if you see any water in there.
fromme is offline
post #9 of 13 Old 08-17-2009, 10:04 AM Thread Starter
srtreat83
We tried the WD 40 thing.... and we dried out the distibutor cap. Its been over a week... we are thinking it is an electrical problem.
post #10 of 13 Old 08-17-2009, 10:05 AM Thread Starter
srtreat83
It would just be nice to not have to worry about having something to drive to work/school when we get home if we took a vehicle we didn't drive everyday.
post #11 of 13 Old 08-17-2009, 10:46 AM
srlbotanical
Its an electrical issue. Water is still somewhere shorting out a sensor or shorting out the ignition. You did not suck water into the engine. If so, you would have hydro-locked that first time you tried to start it...
As a side note, if a vehicle ever dies in deep water, pull the plugs BEFORE you try to crank it over the first time. It may save your engine.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #12 of 13 Old 08-17-2009, 11:42 AM
NotURMailman
NotURMailman's Avatar
It is possible, though not the most likely thing, that you got water in your fuel...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #13 of 13 Old 08-17-2009, 11:48 AM
htownjeep
What's that noise?
htownjeep's Avatar
Something similar happened to me once and this was the problem. It could be a lot of things though. Definitely check this though.
Drink upstream from the herd.
htownjeep is offline
Jeep dies when in drive Plowhoss YJ Wrangler Technical Forum 10 10-06-2009 04:54 PM
Jeep dies when put into drive PLEASE HELP it is my only DD!!! HowIRoll TJ Wrangler Technical Forum 13 07-29-2008 01:54 PM
Jeep Dies 88mudder YJ Wrangler Technical Forum 5 04-20-2007 01:21 PM
Jeep dies. psychoticj TJ Wrangler Technical Forum 7 02-06-2007 12:21 PM
Jeep dies when it warms up?!?!? RabiDaWise YJ Wrangler Technical Forum 9 03-12-2005 08:16 AM
