Got me some new axles (swap and gear ?) - JeepForum.com
post #1 of 5 Old 12-27-2013, 05:46 PM Thread Starter
tcate23-97
Hopefully everyone has had happy holidays, should be my last new thread for a while...maybe not.
Anyways, was able to pick up D30/D35 axles with 4.10 gears for a GREAT price so I jumped on that instead of dropping 1600 (best price I could find) on a regear. While I will 100% regear eventually, I am on a major time constraint and am unsure of my final tire size.
I would like to keep my rear axle and use the new front i got...but i need the 4.10 setup out of the new axle. Is there anyway for me to sway the carrier w/the gear and pinion in place to my old rear. What alignment problems would I run into?
P.S- Any suggestions on anything to do to the new axles? Already planning on cleaning them down good and throwing a layer or two of black rust prevention paint just in case.
Thank you as always! Very appreciative of the help given on jeep forum.
tcate23-97 is offline
post #2 of 5 Old 12-27-2013, 05:52 PM
robncar
robncar's Avatar
If you pull the gears/carrier from the old axle and move them to the new, you'll need to setup the gears again.
What trans?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 5 Old 12-27-2013, 06:01 PM Thread Starter
tcate23-97
What trans?
AX-15 5 spd manual. And so essentially it would be near the same process as regearing the axle, in relation to setting up the gears?
post #4 of 5 Old 12-27-2013, 06:08 PM
robncar
robncar's Avatar
Yes, same as a re-gear. Your profile shows 33's, so with the 5-speed and 33's you'd want 4.56. But, the 4.10s will be an improvement over the 3.07's. If the future is 35's, I'd lose the D35 anyway.
robncar is offline
post #5 of 5 Old 12-27-2013, 06:53 PM Thread Starter
tcate23-97
Yes, I was initially going to 4.56 but like I said above, had time constraints on either getting it doe or doing nothing for a few months and couldn't find someone trustworthy to work on it. Hoping the 4.10 will be a big boost, then will finish everything else once i decide on "permanent" tires and suspension setup.
