Got a check engine light today on my 98 TJ after replacing a brake line last night. T - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Got a check engine light today on my 98 TJ after replacing a brake line last night. T
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-17-2014, 01:38 PM   #1
calhoward96
Pic: http://i.imgur.com/LnLYS6H.jpg
I had to disconnect this hose and another to get a new brake line in. Apparently I didn't put it back on snugly enough because when I left from work today I found the check engine light was on. I noticed this hose was disconnected when I looked under the hood, so I put it back on thinking I'd solved the issue. The light is still on. I've had no issues with the engine thus far, no overheating, oil is fine. I dunno what to do from here besides rolling it into a shop, but I've never had to repair the TJ at an auto shop and I'd prefer to solve this myself, especially since it seems I know exactly what caused it. Advice?
calhoward96 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2014, 01:44 PM   #2
biffgnar
biffgnar's Avatar
Some codes take a little while to reset. If you want to reset manually disconnect the battery for a little while. Could be useful to have the code read and confirm it is related to the vacuum hose ior is coincidentally a different issue.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread 09-17-2014, 02:04 PM   #3
calhoward96
Thanks, problem solved.
