Goodbye Long Arms... hello short arms - Page 7 - JeepForum.com
post #91 of 731 Old 07-29-2010, 09:07 PM
lumpster
lumpster's Avatar
Toys by Troy Alumiflex suspension. Cool.
i dont know about "cool"
lumpster is offline
post #92 of 731 Old 07-29-2010, 09:12 PM
lumpster
lumpster's Avatar
What's a suspension calculator going to tell me?
I was under the impression they calculated stuff like anti-squat, roll center, etc.. to make sure your jeep wouldnt stink bug when you hit the gas and stuff
How many do you see that are set up for 25-27" arms?
Once again "i was under the impression" that the poly brackets for example could be used with what ever control arm length you wanted since they sold 3 foot and 4 foot, why couldnt you make them 26-30 inches? You have to weld the threaded bungs in anyways.
lumpster is offline
post #93 of 731 Old 07-29-2010, 09:28 PM
Sundowner
Interesting information so far. I almost understand parts of it.
Sundowner is offline
post #94 of 731 Old 07-29-2010, 09:34 PM
DaleII
Alright Dale, just for you-
What the hell is that!? I have never seen anything like that before.. I don't get what goes where either.. Are there any pics I can see of it on the rig? Like old pics? By the looks of it, I want nothing to do with it. Regardless..
2005 Silver LJ
DaleII is offline
post #95 of 731 Old 07-29-2010, 09:35 PM
Climbit
I love how every suspension thread turns into a heated argument over whether or not Blaine knows what he is doing
this should be fun.
also I am assuming that that TBT alumi-flex is they "radius rod" system that nobody likes. or am I wrong?
Climbit is offline
post #96 of 731 Old 07-29-2010, 09:40 PM
DaleII
I think so. But I don't get it at all.. I don't see how or why..
2005 Silver LJ
DaleII is offline
post #97 of 731 Old 07-29-2010, 09:55 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Go look at the first picture. I set it on the ground the same way it came out of the rig.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #98 of 731 Old 07-29-2010, 09:56 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I read part of your long arm low lift thread and you need to study up some more.
Those telling you that longer arms are required for a good ride, handling and performance on the trail are full of it.
I am Savvy
mrblaine is offline
post #99 of 731 Old 07-29-2010, 09:59 PM
Apex
Recon death squad
Apex's Avatar
So that single flex joint is where the it mounts to the LCA bracket at he frame? And then there is an upper and lower from a single fixed point? Looks weird...makes sense in an "extended radius arm" type of setup... still confusing.
Apex is offline
post #100 of 731 Old 07-29-2010, 10:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not radius arm, radius rod, big difference in this application.
I am Savvy
mrblaine is offline
post #101 of 731 Old 07-29-2010, 10:05 PM
Apex
Recon death squad
Apex's Avatar
Oh no, I know that isn't a radius arm... What I was getting at is that if you took a radius arm and slung it all the way up to mount at the same point as the LCA bracket then you'd have the radius rod. So it would seem to be somewhat of the same premise, but it doesn't make much sense to me.
Apex is offline
post #102 of 731 Old 07-29-2010, 10:20 PM
DaleII
Does the single joint connect to the axle or the two joints?
2005 Silver LJ
DaleII is offline
post #103 of 731 Old 07-29-2010, 10:21 PM
Apex
Recon death squad
Apex's Avatar
Look at the upper arm and the bracket on the end...the single joint goes to the frame.
Apex is offline
post #104 of 731 Old 07-29-2010, 10:36 PM
RaggedOleMan
Originally Posted by DaleII;9875221[COLOR="Blue"
]What the hell is that!?[/COLOR] I have never seen anything like that before.. I don't get what goes where either.. Are there any pics I can see of it on the rig? Like old pics? By the looks of it, I want nothing to do with it. Regardless..
DaleII; I bout' died when I read; "What the hell is that?"
At the risk of pestering Blaine and Robert, I for one am hoping someone will slip in a little suspension 101 in the thread in the form of diagrams or pictures, perhaps in-between Blaine's posts? This internet education is bit difficult...
What the hell is that? I thought I was alone in the confusion...
RaggedOleMan is offline
post #105 of 731 Old 07-29-2010, 10:53 PM
LuckRider
LuckRider's Avatar
Am I the only one that is confused why savvy is listed as a tag? There is nothing savvy about this thread. They will not be making any products, and there is no mod of any of their products except for the UA which is irrelevant to the topic at hand.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
