Goodbye Long Arms... hello short arms - Page 47 - JeepForum.com
post #691 of 731 Old 01-22-2014, 07:25 PM Thread Starter
Robert J. yates
Originally Posted by GrantTJ View Post
Damn I'm poor.
Me too LOL.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #692 of 731 Old 01-23-2014, 06:22 AM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Just reread through this build. It's nice to know that the factory Currie trackbar/steering/PSC assist, are all playing nicely with the Blaine designed suspension mods. Besides the tie rod flip and track bar bracket relocations, the frame notch, and the modifications for mounting the shocks, was there anything else that had to be tweaked to make the bolt on parts play well with the custom fabricated stuff?
My newest build:
Necromancer_tat is offline
post #693 of 731 Old 01-23-2014, 07:49 AM Thread Starter
Robert J. yates
The frame notch was needed when we repurposed the original crossover steering. It isn't needed with the new axle with the Currie set up so you can forget about that if you go Currie.
The fabrication for the emissions canister relocation to accommodate the PSC reservoir tried Blaine's patience In the later models, it's easier. My tray mounted ARB compressor also had to be taken apart, rotated and tucked underneath the Hydrobooster.
For some reason, the coil buckets on the new axle were off substantially from the factory and a new set of Currie springs was needed to clear the shock towers as the old springs were put into an arc and interfered with them.
Beyond those particular issues..... There is a ton of Blaine's fabrication work in the lower and upper shock mounts as well as the axle sleeve/truss. The tie rod flip kit is also used with the sway bar bracket relocation and the "C"'s have gussets along with work needed to accommodate the ram at the axle.
As for the PSC stuff..... It is matched extremely well. I used to run a Tommy Lee pump, box and reservoir along with the Hydrobooster. I got some funky feedback in both the brake pedal and steering as well as the pump howling at speed and poor on center feel on pavement. This isn't necessarily a dig at Tommy's stuff and it was the best out there 10 years ago and I always had plenty of power off road. It's more a point of the constant improvement that has taken place along with a critical eye towards matching parts and flow. The PSC stuff is invisible on road.... I even let my wife drive this truck around which says a lot for it build wise that she can get in it, turn the key and drive it like any other car.
post #694 of 731 Old 01-23-2014, 08:02 AM
Necromancer_tat
2015 JK Wrangler
That's nice to know. I'm building something similar, but for now I'm sticking with short arms in the factory locations. I'll upgrade to the mid arms after I've gotten everything else sorted out and playing nicely together. I still have a long way to go to catch up. It all seems nice and simple, but the parts add up pretty quickly.
My newest build:
post #695 of 731 Old 01-23-2014, 08:48 AM Thread Starter
Robert J. yates
We knew when we first did the mid arm that we were going to have to dig into the front axle and the steering and I needed some time to put more cash together which is why this build happened in 2 phases. The PSC stuff isn't cheap... Same with the Currie.
post #696 of 731 Old 01-23-2014, 08:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Painfully quickly.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #697 of 731 Old 06-16-2014, 11:10 AM Thread Starter
Robert J. yates
So I am down to the last few modifications on my list... new seats being one of them and a rear Antirock being the other. The seats I can do myself, the Antirock is another story so today, we are updating the seats.
My 16 year old stock factory seats were no fun to ride in since they are pretty much non-supportive and the foam is disintegrating. I never really had a problem with these seats as they fit me pretty well but it finally got to the point where my back was hurting after sitting in them for a few hours at a time.
Of course since I am a fanboy, I worked with Savvy and Gerald made me a smoking deal on a set of Daily Drivers from PRP. We included the necessary brackets and also a matching seat cover for the fold and tumble rear seat. What I liked in working with PRP is the fact that there are quite a few options available for trim and fabric so I was able to get the color match I wanted. What I didn't like was the trouble I had with the brackets... the brackets were not shipped with the original order for some reason even though they were on the invoice. PRP quickly tried to make it right by overnighting me a bracket set but then that set came incomplete. Third time was the charm and I finally had everything I needed for a complete install.
The process for swapping out the seats is relatively uneventful... remove the nuts off the 4 seat studs.... I used a 13mm ratcheting box wrench... eliminate the fold and tumble cables, install the adapter brackets back onto the existing seat studs by reusing the 4 nuts, and then finally bolting the seats to the new adapter brackets with the supplied 9/16ths hardware.
The interesting thing was the difference between the 2 fold and tumble mechanisms on the driver and passenger sides. If Jeep used the same mechanism on the passenger side as they did on the driver side, most people would not have to deal with the cable assembly crapping out on them. The driver mechanism is more robust, uses a spring and is easily removed with an e-clip. PRP does not make a provision for the cable but I cleaned and lubed the mechanisms and the sliders so all it takes is to reach under the seat and hit the release lever.
Overall, I'm pretty happy with the result and having my legs supported again should help on long days in the seats.
post #698 of 731 Old 06-16-2014, 11:46 AM
robncar
robncar's Avatar
Those look great, I like the tweed...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #699 of 731 Old 06-16-2014, 12:11 PM
aparke4
aparke4 is offline
post #700 of 731 Old 06-16-2014, 12:15 PM
2k2wranglerx
I run the teraflex rear sway bar and really like it. Super easy install too.
cut a few notches, weld in a few tabs and you're done...
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
post #701 of 731 Old 06-16-2014, 12:20 PM
biffgnar
biffgnar's Avatar
Interesting comments on stock seat differences. When I switched mine the fold and tumble mechanism seemed the same on both sides. Perhaps it's different in different years or maybe DC had multiple seat suppliers that had slight differences and they used each day on the line whatever they randomly had in inventory.
Romney in 2020!
biffgnar is offline
post #702 of 731 Old 06-16-2014, 12:43 PM Thread Starter
Robert J. yates
I've been in some TJ's where the driver side does not fold and tumble so who knows what Jeep was up to. My passenger side had the broken cable issue but the drivers was fine.
post #703 of 731 Old 06-16-2014, 12:45 PM Thread Starter
Robert J. yates
I won't ever install anything Teraflex ever again. BTDT
post #704 of 731 Old 06-16-2014, 04:09 PM
Imped
Imped's Avatar
Looks good, I run the same seats with Cordura centers and like them a lot. The side bolsters make entering and exiting the Jeep a little tougher but the extra support is well worth it.
OlllllllO
IndyORV
Imped is offline
post #705 of 731 Old 06-16-2014, 05:19 PM
2k2wranglerx
I originally ordered an anti rock but they were on backorder and couldn't give me a delivery date. And no rear sway bar sucked.
This one was in stock. So it won. So far so good.
And no idea what btdt means.
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
