Goodbye Long Arms... hello short arms - Page 43 - JeepForum.com
post #631 of 731 Old 11-12-2013, 05:54 PM
aparke4
what temp does your power steering fluid run at with the hydro assist?
aparke4 is offline
post #632 of 731 Old 11-12-2013, 08:58 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
about 45 minutes ago while google searching body mounts.
They aren't OEM and they didn't come that way from the factory.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #633 of 731 Old 11-12-2013, 08:59 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Same temp it runs without assist.
I am Savvy
post #634 of 731 Old 11-12-2013, 10:54 PM Thread Starter
Robert J. yates
Does PSC even manufacture a reservoir with a bung for a sender?
BTW Blaine.... I told Andrew that he could have the aluminum tailgate hinge take-offs.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #635 of 731 Old 11-13-2013, 08:15 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
They have an AUX port on the reservoir. If you weren't using it for the hydroboost return, it could be used for a temp sender.
I am Savvy
post #636 of 731 Old 11-13-2013, 02:07 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
What do you do when your rear shocks need to be fixed? Get a magic tape measure and I just happen to own one.
Just in case you suck at dimensional math.
Installed in the rear application on Robert's rig they show just a smidge or two more than 6" of up-travel at ride height.
It was done that way to save the modification of the previously installed Poly outboard shock kit. This made it a direct bolt in.
I am Savvy
post #637 of 731 Old 11-13-2013, 02:14 PM
Garza
Cheater!! I knew my orange tape measure wasn't the right one!!
Garza is offline
post #638 of 731 Old 11-13-2013, 02:19 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's not cheating if you know a guy and I just happen to know a guy.
I am Savvy
post #639 of 731 Old 11-13-2013, 09:56 PM Thread Starter
Robert J. yates
That guy has come in very handy.... Saved me $$ on the rear and used that savings on the front.
post #640 of 731 Old 11-13-2013, 10:03 PM
pcoplin
Looks great Robert! Clean work Blaine.
However, with all of that work on that front axle, I would think you'd have upgraded it sometime.
FullStack MotorSports
pcoplin is offline
post #641 of 731 Old 11-13-2013, 10:16 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It is upgraded. It's High Pinion, ARB, Warn locking hubs, Currie mini skids, raised swaybar link mounts, flipped Currie tie rod, 15" big brake kit, 2.5" JJ single upper on a mini truss, CTM u-joints, Warn full hardened alloy inners and outers, hydro assist, and if the polish on that turd were any higher, I'd have to wear my sunglasses to get near it.
What else does it need that it doesn't have?
I am Savvy
post #642 of 731 Old 11-13-2013, 10:25 PM
JJeeper09
Originally Posted by mrblaine
It is upgraded. It's High Pinion, ARB, Warn locking hubs, Currie mini skids, raised swaybar link mounts, flipped Currie tie rod, 15" big brake kit, 2.5" JJ single upper on a mini truss, CTM u-joints, Warn full hardened alloy inners and outers, hydro assist, and if the polish on that turd were any higher, I'd have to wear my sunglasses to get near it. What else does it need that it doesn't have?
Chrome diff cover.
That axle sounds perfect
JJeeper09 is offline
post #643 of 731 Old 11-13-2013, 10:28 PM
pcoplin
1480 u-joints.
Mine has all that other crap. I still cringe when I put my tire against a vertical and press the throttle...
pcoplin is offline
post #644 of 731 Old 11-13-2013, 11:19 PM
Climbit
he's either talking about the 30spline kit, or a Dana 60.
Climbit is offline
post #645 of 731 Old 11-14-2013, 03:35 AM Thread Starter
Robert J. yates
1480 u-joints.
My issues had nothing to do with the durability of the previous HP30 since it basically survived a ton of trail use and various modification attempts. Basically, getting suckered into crossover steering meant that it was easier to start over rather than trying to hack all of that off to get back to a stock configuration. I'm also never going beyond 35's, I'm not running a V8 and we already dropped about 300lbs off the truck by getting rid of the long arm and steel armor..... Knowing how and where I drive, no cringing will be involved.
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
