Goodbye Long Arms... hello short arms - Page 42 - JeepForum.com
post #616 of 731 Old 11-12-2013, 07:16 AM
rebelbowtie
Originally Posted by mrblaine
Stock bolt from Currie and there is a very good reason for the length.
I'll bite, what's the reason?
rebelbowtie is offline
post #617 of 731 Old 11-12-2013, 07:46 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The length is to move the grip range up into the frame side mount hole as far as possible and still have enough threads for the bolt to be tightened fully.
The grip range of a bolt is the length of the shank without threads. There is a theory that the fewer threads in the loaded area of a bolted connection, the smaller the likelihood of breaking the bolt is.
Most of the desert go fast guys buy bolts that have shanks long enough to hit both tabs on a bolted connection and then cut the excess threads off.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #618 of 731 Old 11-12-2013, 07:48 AM
rebelbowtie
I figured it had something to do with the grip of the bolt and not stretching the threads or something. Thanks for the explanation, this bolt comment inspired me to go back and read the beginning of the thread. Lots of knowledge there on radius arms I didn't understand before.
post #619 of 731 Old 11-12-2013, 07:52 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
IIRC, when I clamshelled mine he said it was useless & a waste of time
It is useless and a waste of time. There are times when I indulge myself and my friends and do useless things for them that are a waste of time.
Given that I know Robert's needs and usage for this rig and know beyond a doubt that the chances of him needing or using what I did are less than zero, it's even more useless and a waste of time and tube.
Especially given that his other two front axles had the same size tubes before the clamshell and neither of them wound up bent, I know how much of a waste of time it is.
The main reason I did it? To mess with Robert.
I am Savvy
post #620 of 731 Old 11-12-2013, 07:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Now, if you really want to see useless and a waste of time, tell me what is different about the body mounts I used.
I am Savvy
post #621 of 731 Old 11-12-2013, 09:52 AM
Climbit
I know why it is the length that it is.
but it doesn't need to be.
they managed to get their control arm bolts to have minimal threads through the mount, yet they don't have 2" of extra thread you have to deal with. why they can't do that with the trackbar bolt is a mystery to me.
I would cut it down so I didn't have to deal with threading it on so long
any reason why you didn't use a locking nut?
Climbit is offline
post #622 of 731 Old 11-12-2013, 10:33 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Has ONLY to do with the common lengths of the shanks and I don't think anyone wants to pay for or build custom length bolts.
I don't use the lock nut for set up. That side of the bar is the easiest to move around so I use a normal graded hex nut, tighten the crap out of it and then jam that with the lock nut. I like the extra thread for that reason.
I am Savvy
post #623 of 731 Old 11-12-2013, 11:04 AM
Climbit
I just cut them, file the edges and chase them with the proper die.
fair enough.
Climbit is offline
post #624 of 731 Old 11-12-2013, 11:32 AM Thread Starter
Robert J. yates
LOL.....
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #625 of 731 Old 11-12-2013, 02:54 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
fair enough.
Swing by sometime. I'll show you how to dispense with the file and die and have it work perfectly every single time and start to finish is roughly 30 seconds for a 5/8" bolt.
I am Savvy
post #626 of 731 Old 11-12-2013, 04:00 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Ok i'll bite
as usual you ask a question without giving much details or pictures for ammo. I can't see the whole rubber mount & section from the angle, but obviously the washer is different. Maybe its a conical washer of some sorts to center the bolt in the mount?
I'm surprised you didn't put a skid of some sort on those raised body mounts...kinda just left the bolts hanging out in space to get hit by stuff. Maybe the JKS body mount skids are right up your alley!
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #627 of 731 Old 11-12-2013, 04:36 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Ok i'll bite
And the last time you saw a zinc plated body mount base was?
I am Savvy
post #628 of 731 Old 11-12-2013, 04:43 PM
Unlimited04
about 45 minutes ago while google searching body mounts.
Useful Write-Ups:
Funny:
post #629 of 731 Old 11-12-2013, 05:31 PM
Climbit
I've been meaning to make a trip.
Climbit is offline
post #630 of 731 Old 11-12-2013, 05:45 PM
robncar
robncar's Avatar
Looks great Robert, congrats! I have ram envy...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
