Goodbye Long Arms... hello short arms - Page 4 - JeepForum.com
post #46 of 731 Old 07-27-2010, 10:42 AM
Peterpsc
Maybe, maybe not. I'm not posting any more updates or pictures until someone tells me about radius rod front suspensions.
Told ya I'd enjoy it.
Peterpsc is offline
post #47 of 731 Old 07-27-2010, 10:47 AM
DaleII
All this suspension talk is way over my head. I need to see more pictures to at least start understanding it. I might have an idea of what you're talking about, but I doubt it.
2005 Silver LJ
DaleII is offline
post #48 of 731 Old 07-27-2010, 10:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
on that ford roadster example, i could see lots of torsional effects since the upper and lower mounts want to change planes under flex with the radii the axle housing travels in (with respect to each other - three mounting points wouldn't remain in the same plane).
That's correct and in this instance, the installation of the JJ conversion kit in the upper control arm mounts at the axle resulted in serious bind which started taking their toll on the arm brackets that attached to the upper JJ's on the axle.
Enough so that Robert started breaking them.
i could see how it would work on a roadster where the I-beam doesn't have a lot of travel, but the torsion of off-road suspension would place lots of stress on the union between the two arms and the axle mounts.
How close was that?
Actually the stress is present throughout the whole triangle and it only manifests itself at the weakest point. In this case, the weak point turned out to be the adjustable ends for the uppers at the axle end.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #49 of 731 Old 07-27-2010, 11:23 AM
breckboarder55
Originally Posted by Robert J. yates View Post
Google me.... I either own a NASCAR team or I'm a serial killer LOL
I had googled your name before posting... I'm not a NASCAR fan, so you must be a serial killer. errrrrr wait
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #50 of 731 Old 07-27-2010, 11:42 AM Thread Starter
Robert J. yates
Yes, radius rod, not wristed radius arm, which by the way, the article fairly well screwed the pooch on their reasons to install one.
This about the only part they got right but its not a positive. It occured for the wrong reason as it was installed on my TJ:
"Radius arms have the added benefit of keeping the wheels from moving toward the center of the vehicle during droop and being self-canceling for torque..."
Robert J. yates is offline
post #51 of 731 Old 07-27-2010, 12:10 PM
lumpster
lumpster's Avatar
i think leaf sprung vehicles that have the shackled mounted on the inside like MORE's shackle reversal is about the only suspension that doesnt let the wheel travel inward shortening wheelbase in the process. I guess is you mounted the control arms at the front of the frame, in front of the axle you would get the same effect, a longer wheelbase when drooping.
Blaine, i thought you didnt like RH/LH threads control arms? You going to machine the control arm with a slit and clamp to keep it from loosening?
lumpster is offline
post #52 of 731 Old 07-27-2010, 12:43 PM
homeboy1991
This is going to be a good build.
homeboy1991 is offline
post #53 of 731 Old 07-27-2010, 01:20 PM
kellerumps
kellerumps's Avatar
Agreed......
I don't look for problems....They find me.
Member of:
kellerumps is offline
post #54 of 731 Old 07-27-2010, 03:13 PM
Jetscuh
O rly?
2015
I might just be odd, but the first time I even saw a radius rod style suspension I was thinking 'Why in the hell would I want that (on my lifted TJ)?'
I understand their purpose and design and they may have a place in this world but not on my TJ.
Jetscuh is offline
post #55 of 731 Old 07-27-2010, 04:51 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't like them, but this build is a very good compromise between budget and performance. We have a budget we are trying to stick with and the more parts we have that can possibly be reused, the better it will be.
He also needs some spares and we may have worked out a plan that gives him spares and satisfies my anti-RH/LH stance.
I am Savvy
mrblaine is offline
post #56 of 731 Old 07-27-2010, 05:12 PM
viperbluelx
I always thought a 4-link required 4 control arms?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #57 of 731 Old 07-27-2010, 05:24 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
well...a "4-link" is more like a 5-link if you count the track bar. and 3-link (two lowers, one upper) still requires a track bar...so its more like a 4-link but to confuse you more, theres triangulated 4-links...which don't require track bars
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #58 of 731 Old 07-27-2010, 06:00 PM Thread Starter
Robert J. yates
Building onwhat Blaine said.... the idea is to re-use parts of the lift that are worth reusing so that I could afford upgrades for additional clearance, strength and some of the new Savvy gear. Granted, it doesn't account for much in the scheme of things but the aluminum lower arms are worth saving as they are plenty strong enough for what I plan on doing with this Jeep. We are looking at cutting them down and rethreading them to accomodate the Johnny Joints. The front upper will be the same size as the lowers so it makes sense for us to think about using the aluminum rear lowers up front and crafting new rear lowers which will leave me with a spare up front either for a lower or an upper. We think we have a nice solution for the rears but that will depend on material availability. Going this route, Blaine will get his preference on the RH/LH joint issue I believe
As a side note, I will have some decent gear available for sale but I'll wait until I have complete list of what is not used and deemed worth selling before I post it up.
post #59 of 731 Old 07-27-2010, 06:25 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
got to see this.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #60 of 731 Old 07-27-2010, 09:38 PM
justanotherjpr
Cool!!
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-10-2010 12:07 AM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 04:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 06:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 09:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 08:59 AM
