Goodbye Long Arms... hello short arms - Page 38 - JeepForum.com
post #556 of 731 Old 02-29-2012, 09:33 AM Thread Starter
Robert J. yates
Originally Posted by OldGloryLJ View Post
Thanks, would that be La Verne, Earth?
Yah..... Here on business
I'll get in touch with you later today.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #557 of 731 Old 02-29-2012, 09:36 AM Thread Starter
Robert J. yates
Originally Posted by rippinbmore View Post
That is one filthy looking lift.
check out my jeep
http://mylifeisjeep.blogspot.com/
Do you comprehend the terms "under construction" and "mock-up"? Next time before opening up your mouth, read the entire thread. That picture was from 2 years ago.
post #558 of 731 Old 02-29-2012, 12:41 PM
wushaw
Rockin jeep
wushaw's Avatar
I would never re-use the small joint on a single upper due to you now asking 1 arm to do the work that used to be done by two. I firmly believe in using the larger joints found in the lower arms on both ends of a smaller diameter single upper link.
You are welcome to disregard any and all of that drivel though.
Personally, I think the 2" joints are too small. Even if it were seen as "feasible", my decision is already made up. I'd be much less worried about the cast mount and more worried about that tiny joint. I plan on using 1.25" shank 2.5" JJ's if I move to a single upper.
X2 on all this.
wushaw is offline
post #559 of 731 Old 02-29-2012, 01:57 PM
pcoplin
Originally Posted by wushaw View Post
X2 on all this.
I agree, and have built as such. But I'm wondering if there have actually been any failures, not only just because we *think* it's not enough joint. I know I do, but it's something to think about.
FullStack MotorSports
pcoplin is offline
post #560 of 731 Old 02-29-2012, 02:07 PM
Imped
Imped's Avatar
I wouldn't be worried about the actual joint or even a bolt (providing you used a 1/2" or larger center ball) failing. The smaller joints are just not as preloaded and the bushing halves are smaller. It certainly wouldn't happen overnight but they'd wear out....at least that's what I feel would be the case. They do fine when sharing the load but the bigger joints have been proven to hold up no matter what for a very long time.
OlllllllO
IndyORV
Imped is offline
post #561 of 731 Old 02-29-2012, 02:52 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's not a strength issue. You can take a 3/4 x 3/4" rod end and use it in a lower link all day long without approaching it's 40,000 odd pound rated static load capacity, they just wear out faster than the 1 x 1.25's do.
Same with the small upper, the joints will wear faster but I'm pretty sure they wouldn't fail under normal use.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #562 of 731 Old 02-29-2012, 03:24 PM
Necromancer_tat
Where'd all my money go?
With the larger upper joint, is the strength enough to compensate for side to side movement of the axle when combined with the 2 lower joints, and the trackbar joints in a DW situation? It seems like only having one upper joint would leave the axle centering responsibility to the track bar joints and the lower control arm joints... so should all of those be upgraded as well?
Necromancer_tat is offline
post #563 of 731 Old 02-29-2012, 03:30 PM
Imped
Imped's Avatar
How do you intend to upgrade over the big 2.5" JJ's?
OlllllllO
IndyORV
Imped is offline
post #564 of 731 Old 02-29-2012, 03:49 PM
Climbit
why the billet chromolly joints with the chemically polished center balls of course
Climbit is offline
post #565 of 731 Old 02-29-2012, 04:20 PM
pcoplin
Pretty sure you could mount 12 parallel links and the trackbar is all that will locate the axle. That's why it's called a TRACK bar. The links aren't going to see any side load from the axle.
pcoplin is offline
post #566 of 731 Old 02-29-2012, 04:41 PM
Necromancer_tat
I don't. They're nice and beefy. I'm curious about the axle side to side movement while only using one upper joint? I'm not saying it isn't plenty, I'm just wondering how it compares.
The new Billet joints are sexxy, but not what I'm wondering about.
First off, there would be no need ever for 12 parallel links to locate an axle. Second, at the axle side only 3 attachment points are needed to locate it.
Third, the links experience axial loading, thus they see minimal side loads...
4th, a triangulated 4 link has no need for a track bar to locate the axle.
post #567 of 731 Old 02-29-2012, 04:42 PM
pcoplin
Third, the links experience axial loading, thus they will never never see side loads...
Really? Then WTF are you asking above?
pcoplin is offline
post #568 of 731 Old 02-29-2012, 04:51 PM
Necromancer_tat
I was asking if the larger single upper joint in a 3 link set up was strong enough to help the track bar out in reguards to keeping the front axle in line.
post #569 of 731 Old 02-29-2012, 05:05 PM
Deacon
Shining Adonis
Deacon's Avatar
The stock location upper link does not help the track bar keep anything in line in the first place, so the point is moot.
Deacon is offline
post #570 of 731 Old 02-29-2012, 05:10 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Really? So, if I remove all four control arms and push on the axle directly sideways, it won't move to the front or back?
I am Savvy
mrblaine is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
