Goodbye Long Arms... hello short arms - Page 16 - JeepForum.com
post #226 of 731 Old 08-05-2010, 12:58 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by lumpster View Post
arent they just redrilled up higher? Looks like good start though
Yes, JUST redrilled up higher. Try it sometime and get back to me without pulling the axles.
But, they are at the exact bolt height I would have made custom tabs for and all I have to do to finish these off is put a small plate across the bottom to tie the sides of the stock brackets back into the tube. The weld washers are 3/16's and fully welded for both ends of the bolt.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #227 of 731 Old 08-05-2010, 01:28 AM
lumpster
lumpster's Avatar
90 deg drill?
Im a machinist, so id go about it the hard way and pull the axles.
BTW Blaine, you never got back with me on the superwinch/warn plug thing.
lumpster is offline
post #228 of 731 Old 08-05-2010, 11:02 AM Thread Starter
Robert J. yates
Blaine pretty much said it all but comments like that crack me up. I was there while he and Chris were getting both sides done and while I have a pretty well stocked garage myself, I would by no means think this was a piece of cake.
Robert J. yates is offline
post #229 of 731 Old 08-05-2010, 11:07 AM
lumpster
lumpster's Avatar
Robert, I like to poke at Blaine, just as he likes to poke at me.
I had enough fun mounting the rear trackbar relocator from currie to know that id have to take the axles out and probably the whole rearend out to redrill the control arm mounts. Im a big guy, not a contortionist, but at least my jeep is tall enough i can get on the creeper and roll under the jeep with room to work now.
What is the vertical seperation going to be on the axle now that the control arm mounts are moved?
on an unrelated note, I cant believe what currie wants for chromoly barrels! WOW
lumpster is offline
post #230 of 731 Old 08-05-2010, 12:01 PM Thread Starter
Robert J. yates
That is actually the issue at hand... with the TXT truss it was around 11" at the axle...not good and that in concert with almost very little separation at the crossmember pretty much accounts for the reason why the long arm wanted to unload on climbs. When I was there yesterday one of the first things I said to Blaine was that the truss was too tall so moving the arms up on the existing mounts 1.25" has already helped. We also gained around 2" of clearance as we cleaned up the bottom of the existing mounts.
As for where we are going... we are shooting for around 8" so the next chore is trying to figure out where we can get the rear upper joints mounted on the truss. We have already confirmed that we can use the 7/8ths shank rod ends with the existing AL uppers so that is one less thing to have to fabricate which = less $$$.
post #231 of 731 Old 08-06-2010, 07:56 AM
Sundowner
This makes so much more sense after figuring out the anti-squat problems and why they're showing up.
Sundowner is offline
post #232 of 731 Old 08-06-2010, 12:53 PM
rs4race
I'm interested in Redrilling the stock brackets. It sounds like on the axle side that's what you've done. I've seen it before in an aev installation manual. I know this is far from stock but any speculation on what effect this would have on stockish length adjustable arms and stock mounts?
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #233 of 731 Old 08-06-2010, 01:09 PM
Dogman
Dogman's Avatar
If you move the lowers, you need to move the uppers to maintain separation. That is unless you're trying to change the handling characteristics.
I too like the way that was done. It's nice to know that's an option when trying to improve clearance.
John 3:17
Dogman is offline
post #234 of 731 Old 08-06-2010, 06:56 PM
DRIVESHAFT
Long arms rule!!!!
LONG ARMS RULE!!!! except for hanging up on the occasional rock with the rear arms----LOL
DRIVESHAFT is offline
post #235 of 731 Old 08-06-2010, 07:06 PM
johnny9
maybe for you but im sure theres more than 500 short arms out there that will make you drool compared too most long arms
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #236 of 731 Old 08-06-2010, 07:07 PM
nriver
2011 JK Wrangler
was there ever a definition of a Long Arm?
Wondering if it would go something like this, for a TJ
Short arm, Arms within 2" of stock, arms mounted in stock locations
Mid Arms, Arms over 2" of stock, arms mounted to the frame
Long Arms, Arms well over stock length mounted to the belly pan
It is fun to watch everyone get up in arms over this
How about this for a definition
Mid Arms, Arms over 2" of stock, mounted to some place other than the stock location
Long Arms, bought in a kit, bolted on somewhere
Why do I post here?
nriver is offline
post #237 of 731 Old 08-06-2010, 08:11 PM
DRIVESHAFT
Why does your profile say your suspension sucks and your future mod is long arms? I don't care I just crack up when the SA vs. LA debate starts. My Jeep came with long arms and that's why I have them.
post #238 of 731 Old 08-06-2010, 08:48 PM
johnny9
well since you mentioned it,i havent looked at the info in a long time lol..guess i should fix it since everything changes,and changed again as of today
build-
johnny9 is offline
post #239 of 731 Old 08-06-2010, 09:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you have a way to show me where those specs from AEV are and how they did it, I would appreciate it. I've never heard of or seen the stock axle side mounts re-drilled before or the weld washers done they way we did it.
I am Savvy
mrblaine is offline
post #240 of 731 Old 08-06-2010, 09:22 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Bruce, you need to do us both a huge favor and give me and any thread I'm involved in a very wide berth. Due to your exhibition of middle school chest thumping and backdoor tactics to get me banned elsewhere, I'm fairly astounded that you even have the audacity to post in one of my threads.
I am Savvy
mrblaine is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-10-2010 12:07 AM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 04:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 06:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 09:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 08:59 AM
