Goodbye Long Arms... hello short arms - Page 14 - JeepForum.com
post #196 of 731 Old 08-03-2010, 10:39 AM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Is the notch ahead of the motor mount? Will it compromise the strength of the frame by basically putting a pivot point for the frame to buckle?
-Dave
AustinCJer is offline
post #197 of 731 Old 08-03-2010, 10:41 AM Thread Starter
Robert J. yates
Originally Posted by Savvy View Post
If I recall those are 11" travel shocks? Could be 12". So, with 5.5" of uptravel he should realize 5.5 to 6.5" of down. That is perfect! Getting to the trail is tough when you only have a few inches of uptravel. A common problem with COG rigs. 10 miles back to camp in the whoops makes for a long ride back.
Pretty close Gerald....they are 11.5" stroke Edelbrocks.
Robert J. yates is offline
post #198 of 731 Old 08-03-2010, 10:42 AM Thread Starter
Robert J. yates
Originally Posted by NotURMailman View Post
Where did that bracket on the axle for the track bar come from? Is that part of the old suspension system or did you make it?
That bracket was part of the crossover steering kit I bought from Troy back in 2004.
post #199 of 731 Old 08-03-2010, 10:47 AM Thread Starter
Robert J. yates
Originally Posted by Phillip View Post
The poly bushing delete on the trackbar looks nice. Troys poly bushing cost me an axle bracket.
That is one of the things that started the rebuild... I blew up the original trackbar bushing and luckily, I caught it before it took out that bracket. I substituted it with a Currie Johnny Joint and subsequently blew up both the upper arm axle brackets a couple of times. Scrounging parts was a PITA since Troys junk uses weird bracket and joint configuations. The stuff I was able to find had dimensional differences as well and I was not able to square the suspension to the frame at the end. Something had to go.
post #200 of 731 Old 08-03-2010, 01:51 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes it's in front of the motor mount. Yes it compromises the strength of the frame. The better question is does it matter? And the answer to that is not in my experience. I've notched many many frames for similar clearance issues and not one of them has ever had a problem as a result of doing do.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #201 of 731 Old 08-03-2010, 01:56 PM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Thats the answer I was looking for. Since its in front of the motor mount, that makes more sense; not as much weight up there to push down on the frame...
Progress is looking good, keep it up.
-Dave
post #202 of 731 Old 08-03-2010, 03:44 PM
wushaw
Rockin jeep
wushaw's Avatar
If notching the frame makes one nervous, one can always weld a doubler around the notch to reinforce the frame.
wushaw is offline
post #203 of 731 Old 08-03-2010, 04:15 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You can also weld a chunk over the top of the notch that equals what's been removed and taper the ends down at a 45 angle to meet the top of the frame.
I am Savvy
post #204 of 731 Old 08-03-2010, 05:30 PM
wushaw
Rockin jeep
wushaw's Avatar
You are absolutely right on that one also, I thought of it but just left it alone.
So did you have to knock the cobweds off the plasma cutter to get some of them curved cuts or was a high speed rotary file involved?
wushaw is offline
post #205 of 731 Old 08-03-2010, 07:36 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Hole saw and a 4 1/2" grinder with a cut-off disc and a flap disc.
In fact, every single tab and mount you see that we made was made the same way, cut 'em out with a cut-off disc on the grinder and then hand finish sand them.
I am Savvy
post #206 of 731 Old 08-03-2010, 07:46 PM
wushaw
Rockin jeep
wushaw's Avatar
I figured several cut-off disk were used, I just didn't think of the hole saw....anything but that **** plasma huh?
Looks good and functional.
wushaw is offline
post #207 of 731 Old 08-03-2010, 08:01 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You bring your plasma or you're welcome to use either of the two sitting on the floor and we'll see who cuts faster and gets done sooner and whose work is cleaner.
I only keep them around because there's always that one little tiny thing I can't get to with the sawsall, die grinder, or cut off disc and that's the only thing that keeps them in the garage. They are most assuredly not my go to tool.
And no on the several discs. Less than 1/8" off of one.
I am Savvy
post #208 of 731 Old 08-03-2010, 08:46 PM
Dogman
Dogman's Avatar
Guess I need to practice more
John 3:17
Dogman is offline
post #209 of 731 Old 08-03-2010, 09:07 PM
DaleII
Two!? I wish I had one.. But I am managing with my cut of wheels.. But for those long cuts a plasma would be nice. I'm not that great with a torch yet either..
2005 Silver LJ
DaleII is offline
post #210 of 731 Old 08-03-2010, 09:08 PM
wushaw
Rockin jeep
wushaw's Avatar
I'm just messin with ya, I know plasma is not your cutting tool of choice.
1/8" with that much cutting, what brand disk are ya using?
wushaw is offline
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-09-2010 11:07 PM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 03:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 07:59 AM
