Goodbye Long Arms... hello short arms - Page 10 - JeepForum.com
post #136 of 731 Old 07-30-2010, 09:37 PM
jermeyg
Those are just some scrap DOM 1.5" .120 wall tubing we are using for mock-up with some tube inserts we bought from PolyPerformance.
After it's dialed in, we'll cut the aluminum TBT arms down and get them threaded for the final arms in the front.
Ah that's a good idea, I was wondering why it was just tack welded in place. Looking forward to the continued build.
jermeyg is offline
post #137 of 731 Old 07-30-2010, 10:12 PM
wushaw
Rockin jeep
wushaw's Avatar
A 3 link mid arm....cool
wushaw is offline
post #138 of 731 Old 07-30-2010, 10:27 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Blaine,
Are you going to align the TB and DL? On the truss are you tying it in to the front diff cover or does it matter?
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #139 of 731 Old 07-30-2010, 10:50 PM
johnny9
very nice work..so,this 3 link is less likely (or wont) unload on steep climbs like a radius arm setup..
my radius arm build this weekend is kinda on hold now,,thanks a lot
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #140 of 731 Old 07-30-2010, 11:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Savvy View Post
Blaine,
The initial plan was 3 phases broken down as follows. Tune up the front suspension, tune up the rear and then see how it handles and make the decision to monkey with the steering.
After viewing the front and giving it a bit of evaluation, I suspected that after we got the bind out of the front, the steering's inherent issues would show up at which point we would re-do a few things and get it proper.
Upon cycling the front axle this morning, we discovered that later is now sooner and we'll need to lower the trackbar mount to clear the frame on the passenger side and then move it forward to clear the diff on the driver's side.
The truss will be left as is with a predetermined solution to be implemented later if it decides to move at all.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #141 of 731 Old 07-31-2010, 01:29 AM Thread Starter
Robert J. yates
The 3 link is just plain awesome. We have 8.5" of vertical separation between the upper and lower but all that non binding goodness took its toll on the TXT trackbar and in order to get full compression and uptravel, something will have to give and it won't be the diff or the frame. We could ignore it and bumpstop it so as to not to have to deal with it but I want it done right. We decided this morning after cycling the front end that we will take the trackbar at the frame mount, rotate it on its side and move it forward. We will then take the Johnny Joint I rigged into the axle side, remove it, drop the mount down and use a heim joint so as to provide clearance... you can see what we are dealing with in the second pic. This will also align the draglink to the trackbar. Most likely I will have some bumpsteer with the short trackbar but that will have to do for now.
Now... with respect to whoever complained about this not being a Savvy build... well you just weren't paying attention. I never said it would be. I am relying on Blaine's knowledge and skill in rectifying a number of issues I had with the TXT suspension while adding Savvy equipment where I can. The first thing to go was the Genrite 24 gallon tank with a stock tank with a new Savvy skid along with a 1.25" body lift taking its place. I gained a ton of clearance here and we are now set up for getting Savvy Underarmor into place once we get the suspension figured out.
As for the rest of the build.... well, we will progress as funds allow. The last pic clearly shows what I am dealing with... you can see that stupid long arm belly skid still holding up the rear end with the mocked up 3 link in place.
This work does not pop out of thin air...there is both skill and budget involved here. I had alot of crap that needed to be corrected and I trust Blaine implicitly in helping me get it done.
Robert J. yates is offline
post #142 of 731 Old 07-31-2010, 07:47 AM
snowrydr01
How much vertical separation is on the frame side mounts? any more pictures from different angles?
snowrydr01 is offline
post #143 of 731 Old 07-31-2010, 07:57 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
They are nearly parallel. There is 1.5 of caster change from full stuff to full droop.
I am Savvy
mrblaine is offline
post #144 of 731 Old 07-31-2010, 08:21 AM
snowrydr01
mg]
My bad, i meant more pictures of the upper control arm mount. With it that high im definitely interested of how you fit it and got your clean welds in around the brake lines
post #145 of 731 Old 07-31-2010, 09:01 AM
Bennettj13
You aren't trusting Blaines trigger welds are you? Brave man.
Looks good bud. It will be interesting to see it all come together.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #146 of 731 Old 07-31-2010, 09:22 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If I do need to trigger weld something, you can rest assured that it will work just fine. But, for the sake of entertaining the non weldors, which one were you referring to? Based on the pics posted so far, you wouldn't know a trigger weld if it ran over you.
What else does it need?
I am Savvy
mrblaine is offline
post #147 of 731 Old 07-31-2010, 09:30 AM
lumpster
lumpster's Avatar
I think he was refering to you doing it in stages. So you tell us what else it needs! sounds like the rear end, and steering/front track bar to me.
you have to have the arms shortened and retapped, from the pics it looks like you need to finish weld and paint everything. Install coils, shocks, sway bar, front driveshaft and the Under Armor.
Looks great though, excellent work btw.
lumpster is offline
post #148 of 731 Old 07-31-2010, 09:40 AM
snowrydr01
Certainly not. Im merely requesting a little better picture of the upper CA frameside mount. That is a tricky area as far as space, brake line routing. and weld angles go as apposed to a lower CA mount.
Nothing on Blaine, just more about my own curiosity
post #149 of 731 Old 07-31-2010, 11:33 AM
johnny9
looks like its getting to the easy part! welding it. sure,maybe a lil cramped but whats been done is the hard part to most of us..thanks for sharing this with us normal guys
if i get a straight answer i may try this for the fun of it since i have all the joints and abitlity to make the rest..i need my brain work to stay afloat..not that it would be a fast thing for me.
blaine ,would you feel as safe on the hwy with this as with a radius set up..or maybe safer?
build-
johnny9 is offline
post #150 of 731 Old 07-31-2010, 11:47 AM
Bennettj13
You know I'm just busting balls.
And I wasn't saying it needed anything. I was saying I want to see it all done.
control arms , currie , custom , fabrication , long arms , mod , modification , savvy , short arms , suspension , tj , wrangler
short arms vs long arms AlabamaTJ98 TJ Wrangler Technical Forum 15 03-10-2010 12:07 AM
Ride difference between long and short arms FatBuoy JK Wrangler Technical Forum 7 01-08-2009 04:20 PM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 06:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 09:20 AM
Best TJ short arms smurison14 TJ Wrangler Technical Forum 16 08-04-2006 08:59 AM
