Good Header For my 98 TJ - JeepForum.com
post #1 of 23 Old 11-21-2002, 07:38 PM Thread Starter
Mr Ouija
Mr Ouija's Avatar
Can anyone recommend a good header for my 1998 TJ. I need something that won't involve cutting and welding, something that will bolt directly to my stock intermediate pipe. Is it a tough job? Will they sound good (esp w/ my dynomax cat-back system)? And finally, is the power-gain good? Thanks!!!
98 TJ Sahara Black 5 Spd
Dynomax Stainless Exhaust
K&N Intake
PROComp Stage II 4" Sus. Lift
PROComp Mud Terrain 33x12.5" x 15"
PROComp ES2000 Steering Stabilizer
A/R Outlaws 15x8x3.75" Backspacing
AA Slip-Yoke Elim. & Tom Wood D/Shaft
Mr Ouija is offline
post #2 of 23 Old 11-21-2002, 08:10 PM
jeepdan
jeepdan's Avatar
I installed a borla header, and I love it. Sounds better and performs better. I did the installation and it was a little bit of work. If you are patient and take your time it can be done. Its about a 6-7 hour job. The hardest part is removing everything to get to the manifold (which is probably cracked) then putting it all back together. But it definately can be done, just take your time, you don't want to screw this one up.
Good Luck!!!
1998 -TJ Black Sahara
4.0 I-6, D-44 Rear, 3.37 Gears, 5sp
Custom Exhaust (Borla Headers, Dynomax ST)
RE 2" BB w/ OME Shocks
Teraflex QD's
32x11.50x15 GY MTR's
Soft Bikini and Hard Spice,
Pioneer CD/MP3/WMA/XM
jeepdan is offline
post #3 of 23 Old 11-21-2002, 08:12 PM
demtjcj
borla all the way
2004- Wrangler X stock
1977 full size cherokee-401 v8, quadratrac dana 44s
prev. jeeps: 98TJ on 33s, 00TJ on 35s, 01TJ on 35s, 78CJ on 31s, 85XJ stock, 94ZJ stock, 97 TJ on 35s, 03 on 35s, 93 GC on 33s
demtjcj is offline
post #4 of 23 Old 11-22-2002, 10:04 AM
gtflyer
Banks!..Better overall quality than the Borla header..(i.e thicker flange,better fit etc) and the price is about the same.
gtflyer is offline
post #5 of 23 Old 11-22-2002, 08:38 PM
rogncrys
rogncrys's Avatar
I went with pace setter, cause it was the only I could find at the time for a 4 banger.
98 TJ and 02 Liberty
rogncrys is offline
post #6 of 23 Old 11-22-2002, 11:14 PM
CETROV
CETROV's Avatar
I went with pacesetter too. they tuck up out of the way in the front but I did have to modify the pipes to clear the control arms when you flex.
97 TJ
CETROV is offline
post #7 of 23 Old 11-23-2002, 12:09 PM
Phantom5oh
I went with the Borla, its a great header. Its made of stainless steel and fit like a glove. It was a little more money but I think well worth it!
Phantom5oh is offline
post #8 of 23 Old 11-26-2002, 07:48 AM
duckblaster
i bought a pacesetter and don't like it. you have to use these cheap clamps to hold three pieces of pipe together and it doesn't really fit well. I would go with some other design.
duckblaster is offline
post #9 of 23 Old 12-27-2008, 04:23 PM
Ron R
So whats the best one for the $$
Ron R is offline
post #10 of 23 Old 12-27-2008, 05:59 PM
marko686
I also believe if you go with Borla or Banks you get a lifetime warranty which is good because odds are you will replace it again WHEN it cracks. And the job is not to bad but time consuming.
marko686 is offline
post #11 of 23 Old 12-27-2008, 06:13 PM
rubidriver
When you look at an aftermarket header or even a stock manifold its not IF it cracks, its WHEN it cracks. You have to ask yourself, "is a warrantee worth it?" Do you wanna replace it ever year or two? If I were to replace mine right now, I would buy one with flex tubing at each end. Now by no means is this a "header," its simply a tube manifold. Its your best bet for longevity and its cheaper. Headers on 4.0's normally dont do much for power or milage.
This is the flex manifold I am speaking of.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #12 of 23 Old 12-27-2008, 07:33 PM
fish4life
yeah that doesn't work....
The "flex tubes" are a gimmic. I bought one from a company that used to advertise on this board. I think they're called mid-Atlantic (www.carpartstoyourdoor.com) I had the header on for about a year and a half and it cracked. It cracked where cylinder #5 joins in.
They were good about it and honored the lifetime warranty and sent me a new one, provided i shipped back the broken one. All in all, i was out just for the shipping costs and my own labour to replace it.
But, they DO break. Hopefully my new one lasts longer then 1.5 years.
fish4life is offline
post #13 of 23 Old 12-27-2008, 07:46 PM
rubidriver
Maybe you got a faulty one. Ive heard nothing but good things about these. It doesnt matter which header you get, Banks, Borla, Pasesetter, Doug Thorley, Edelbrock, etc, the simple fact is, it will crack.
It could also be the company you got it from, I know there are a few out there, just not sure which one is suppose to be the best one.
post #14 of 23 Old 12-27-2008, 07:56 PM
fish4life
If that's true and my last one was just a friday manifold, then hopefully that means my new one will last a while ... that would make me a happy man
post #15 of 23 Old 12-27-2008, 08:00 PM
A-P
I have thrown headers on all of my cars so far with the exception of my TJ because I just got it. I have NEVER had headers crack. Race modified 5.0, 03 Cobra, even my 66 Mustang that I have had for 7 years. The only way I can see headers cracking is if you repeatedly go swimming with your Jeep
5-spd 4.0L, 31x12.5-15, XRC8, 2.5" SL, 1" BL
Originally Posted by hoot20 View Post
you know you drive a tj when you can't decide whats louder: the soft top, the tires or the straight pipes
A-P is offline
header , replacement , exhaust , manifold , tj
TPS good wiring, good Code p0121, low voltage, Possible Causes??? ryankikta TJ Wrangler Technical Forum 2 10-02-2009 08:32 AM
New grears for $700 installed good price or sounds to good to be true? sethco JK Wrangler Technical Forum 24 08-10-2009 01:15 PM
whats a good header ionakana YJ Wrangler Technical Forum 10 09-24-2008 10:24 PM
Whats a good header to go with? and how much will i really gain seadooxp6 TJ Wrangler Technical Forum 6 10-25-2006 12:58 AM
whats the cheapest way to lift,lock,gear and still wheel good and handle good EKUSMC TJ Wrangler Technical Forum 16 03-31-2006 09:35 AM
