Is this a good deal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Is this a good deal?
Rough Country Lift Kits now available at Baseline 4x4 OutfHeavy Duty 2007-2013 Jeep JK Wrangler Perfmance Ball Joint1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 05-29-2011, 08:13 AM   #1
bigdog101
hey guys. I found this tj and its pretty close to where I live, and idk if this is a good price. If its not, what is? what would be some things to look for? Thanks!
http://minneapolis.craigslist.org/da...396748368.html
bigdog101 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 08:19 AM   #2
k2quad163
Other than he referred to it as a truck
k2quad163 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 08:20 AM   #3
cfmiller58
id say about average price. i wouldnt pay anymore than that. watch for scammers on CL.
Black Jeep Society
The Build
cfmiller58 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 08:24 AM   #4
inglisleslie
i got my 2000 I6 sport with 60,000 for $7500 2 years ago so id say his asking price is a little high but it depends because jeep prices vary depending where youa re in the country...supply and DEMAND
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline   Reply With Quote Quick reply to this message
Unread 05-29-2011, 08:27 AM   #5
hefightsfire
It looks good to me but check it out in person. Look for rust both on the body and the frame. Ask all the common questions for buying a used vehicle. Get a Carfax, they miss a lot but if it had any major damage it would probably be on there. Look for leaks of any kind. If you meet him where the Jeep is look at the ground under it to see if there are any oil stains. See if the seats and interior are in decent shape. Make sure the doors lock and unlock since it has a hardtop. Look at the tires and see if there is any uneven tire wear. Look at the front and read diff for leaks.
I'm sure you'll get some better advice from the JF heavyweights but that's where I'd start. Hope it helps.
"The problem with quotes on the internet is that you never know if they are real."
Abraham Lincoln
hefightsfire is offline   Reply With Quote Quick reply to this message
Unread 05-30-2011, 01:28 PM   #6
bigdog101
thanks guys. the price for it seems lower than usual compared to most jeeps in this area. thats why id like to look at it. ive seen it while riving but haven't seen it up close yet. hopefully ill get a chance to check it out soon. im not in need of a vehicle at this point, but if i could get a deal on it id do it. otherwise, do you guys think values will drop in 6(ish) months? thats when i get my license, and want to get a good price on a jeep. Thanks!
Unread 05-30-2011, 01:44 PM   #7
plowboy1970
Not bad. See if you can score it for $5000
plowboy1970 is offline   Reply With Quote Quick reply to this message
