Quantcast going over bumps... sounds like transmission is banging around - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > going over bumps... sounds like transmission is banging around
Old 10-12-2002, 07:19 AM   #1
Bryan_16
I've been noticing this for a while but never really thought it was a problem. Just was another jeep thing. But i drove a frineds jeep and it didn't do this at all. I have a 2002 wrangler sport and everytime i hit one of thoes really wide speed bumps it sounds like the transmisssion is banging around... AM i crazy or is this really just a jeep thing?
02 wrangler sport. K&N intake, borla exhaust, Pioneer CD player. 3" lift comming w/ 33" tires.
Bryan_16 is offline   Reply With Quote
Old 10-12-2002, 11:13 AM   #2
KnightFire
Check your trannie mount, make sure its tight.
Thats all I can think of...
KnightFire
2002 TJ Wrangler "X" Patriot Blue 4.0L
1993 Formula Firebird Cardinal Red 355CI
2004 Dodge Ram Hemi-Sport Flame Red 5.7L 4x4
2006 Toyota 4Runner Sport Titanium Metallic 4.7L 4x4
KnightFire is offline   Reply With Quote
Old 10-12-2002, 09:51 PM   #3
Tango
where is the trannie and what does it look like .............mine does the same I really notice the sound when I am in 4low banging around on the rocks seams like when I depress the clutch and take the pressure off the trannie is when I hear it the most .
thanks
P.S. if need be is this hard to replace ?
[url]http://www.mpjai.com[/url]
02 TJ 4.5" of lift , Locked Both ends, with 4.56's pushing 33X12.50 MTR's
[URL=http://rigs.mpjai.com/detail.php?siteid=11]2002 TJ [/URL]
Tango is offline   Reply With Quote
Old 10-12-2002, 09:52 PM   #4
Tango
I ment mount .....where is the trannie mount
thanks
Old 10-13-2002, 01:45 AM   #5
KnightFire
The mount is located under the tunnel brace/skid plate that covers your trannie. It has 6 large bolts holding it to the frame of the Jeep. You will see 4 smaller bolts in the center of said plate, these are what hold the trannie mount to the skid plate.
Make sure you have a jack to lower the skid plate on...while you remove the bolts...or it WILL come down in a hurry. I just use my floor jack and jack up to the plate (just touching it), this way you don't bind the bolts and you can lower the plate easily with the jack.
KnightFire
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
