Going Down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Going Down
Tactical Recovery Equipment Soft Shackles!!!Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWheeler Special! Black Steelies w/ 33" Mickey Thompso
Unread 03-19-2015, 07:38 PM   #1
tomnberta
Going Down
Tom the new guy here with my new to me 2005,
I bought it with a 3" suspension lift and 2"body spacers. I am planning to take the spacers out and lower it a little and find some smaller tires & wheels. After inspecting things I noticed on the steering shaft below the knuckle there is a bearing in a frame looking piece of metal with a 1" square piece of stock holding it up as if it is a spacer, is this for the body lift and if so when I take the body spacers out can I / should take that spacer out from the steering knuckle support also?
thanks
Tom
tomnberta is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 08:57 PM   #2
MikeGordon
Yes, what your describing sounds like part of the body lift. If you're removing the body lift, then that would need to come out too.
MikeGordon is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 05:20 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Remove the steering spacer brace.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 06:00 AM   #4
Denzien
Denzien's Avatar
Misleading thread title
Denzien is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 06:45 AM   #5
tylersheppeard
i agree
Whoever said, "if it ain't broke, don't fix it", obviously never had a Jeep.
tylersheppeard is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 08:01 AM   #6
TheBoogieman
Demonic Jeep Freak!
Unread 03-20-2015, 09:52 AM   #7
joe_jeep
ya, the wife was disappointed!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is online now   Reply With Quote Quick reply to this message
