Going doorless...need mirrors - JeepForum.com
post #1 of 28 Old 04-15-2006, 03:27 PM Thread Starter
Monrozombi
What is the best way to put mirrors on the TJ when the doors are off? I'm not sure where to start looking for them. I'd like to have mirrors when I take the doors off because I don't like not having mirrors. Are replacements available at Pep Boys etc? that can mount to the frame and be somewhat useable?
Thanks
2002 TJ Sport
Engine: 4.0L Auto
Lift: 4" TeraFlex
Tires: 33x10.5 BFG Mud Terrain
Rear End: Dana 44 rear
Monrozombi is offline
post #2 of 28 Old 04-15-2006, 03:38 PM
charlescho
charlescho's Avatar
not having mirrors can be a problem with the local traffic polices....
there are a couple of options,
www.quadratec.com sells some adapters that will let you use your mirrors from your doors, but it comes with a heavy price tag as well...
now some people have been creative and made their own from harley mirrors or any other mirrors lying around...I'm sure they will pop up and help you
ABC - A/Ox4 - SAMPLE - OPQRST
charlescho is offline
post #3 of 28 Old 04-15-2006, 03:39 PM
LSUswanny
LSUswanny is offline
post #4 of 28 Old 04-15-2006, 03:44 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I just use mirror movers which cost about $30.
Like these:
http://www.quadratec.com/products/13125_00.htm
Wheelin98TJ is offline
post #5 of 28 Old 04-15-2006, 03:49 PM
stogie25
stogie25's Avatar
Mirror relocation brackets. Reuse your old mirrors, or scrounge a set for summer.
http://www.rockcrawler.com/techrepor...rors/index.htm
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #6 of 28 Old 04-15-2006, 04:03 PM
Jetmech143
The relocators are the best for your money, you can buy some mirrors that fit where the door pin fits in the hinge but they look kindda tacky in my opinion.
2002 TJ Sport 4.0 Sylver
2.5 in Rancho Susp. Lift, JKS Front Discos
31x10.5 BFG AT's, Cold Air Intake, W/S mounted Daylighters, MM Winch on Tomken plate with light hoop, Bikini/Windjammer/Duster Year round!
Jetmech143 is offline
post #7 of 28 Old 04-15-2006, 04:37 PM Thread Starter
Monrozombi
I like the relocators for $30, they seem the best bet. Does anyone know any B&M stores sell them, really don't wanna wait.
2002 TJ Sport
Engine: 4.0L Auto
Lift: 4" TeraFlex
post #8 of 28 Old 04-15-2006, 06:02 PM
Terps1984
Junior Member
I bought brackets from http://jeepit.com for about 20 bucks, added 5" mirrors from autozone for about 6 bucks. Can't go wrong, no vibration and a better view than stock mirrors. My favorite mod so far.
Terps1984
2003 Wrangler SE
3" Full Traction Lift
BFG 32" ATs
Terps1984 is offline
post #9 of 28 Old 04-15-2006, 06:14 PM
Unionbro
Harley Davidson Universal Long Stem Mirrors work well
http://www.hmhd.com/webstore/viewite...pname=viewprodB
I recently bought this setup and am very happy with it. I came to find out about them from reading on this forum. If you have a local Harley Dealership they can order them and usually would carry them in stock. 24.95 was the price locally for me. The Mirror bolts on the door hing using stock hardware from Harley, I added a stainless washer to the topside to prevent rust.
Unionbro is offline
post #10 of 28 Old 04-15-2006, 06:34 PM
Cowboy1629
Cowboy1629's Avatar
Like these:
Will full doors hit the mirror if you leave the bracket on and reinstall your doors?
Cowboy1629 is offline
post #11 of 28 Old 04-15-2006, 06:55 PM
phydeaux
I have a pair of "Quick Mirrors" from Quadratec that I use. They're kinda pricey but very easy and simple to use. I like'em.
http://www.quadratec.com/products/13120_01.htm
However, I'll probably be going to permanent movers sometime in the future.
'98 TJ Sport, 4.0, 5 spd., 3.73's; 4" RC Series II Lift; 33's, Daily Driver.
Life Member Hummer Recovery Team.
Just
Empty
Every
Pocket
phydeaux is offline
post #12 of 28 Old 04-15-2006, 07:05 PM
stathunter
I bought relocation brackets last summer and then I had to buy new mirrors---because the mirrors from my 04 will not fill on the relocation brackets. It worked perfect but was a little expensive. I was going to leave them on for the winter but the mirror on the passanger side was very hard to see with my full door on---so I switched back and put the origional mirrors on the doors for winter.
I just purchased safari doors and they have mirror holes --not sure if I am going to find mirrors for the holes or use the ones with the relocation brackets.... (always something to buy!)
stathunter is offline
post #13 of 28 Old 04-15-2006, 07:10 PM
Dirty Backroads
Dirty Backroads's Avatar
I have a set of these Harley mirrors I want to sell. Barely used. PM me if anyone is interested. They actually work very well for going doorless but if you want to run soft doors they won't work so that's why I don't even use them anymore because I had to invest in a set of mirrors to work with my Bestop soft doors.
Since I run soft doors I needed mirrors that would install on the windshield. So I bought the Quick Mirror 2s from Quadratec. They mount on the A pillar and you can remove them very easily (very convenient for wheeling and when you use the full doors). No need to move your factory mirrors. You just unscrew 'em and leave the base there.
The downside is that with the upper window halves installed the passenger side mirror isn't useable at all. It is useable when you are dooless or don't have the upper window installed. The driver mirror is just fine. However the mirrors do vibrate a bit. I was having a problem with the mirrors moving around and staying tightened but I use an wrench to tighten the nut down and now they stay put.
I like them because they get job done, look good and are great for the trail. If you have soft doors they can't be beat. They aren't cheap though.
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #14 of 28 Old 04-15-2006, 10:20 PM
NetJunkie
I use these. Cheap and easy. They look great.
http://www.jeepit.com/bracket_gallery_2.htm
'04 Rubicon | Nth Degree 4.5" LA | ORO SwayLoc | ORO U-Turn Steering | 33x12.5x15 MTRs | 15x8 Streetlock Rims | AEV Rockers | ARB Winch Bumper | Warn XD9000i | Offroad-Technology Rear Bumper
NetJunkie is offline
post #15 of 28 Old 04-16-2006, 03:12 AM
BChamberlin
BChamberlin's Avatar
I have a pair of chrome quick mirrors for sale... someone was supposed to send me a check but not sure if they have. I never used them.
2008 Wrangler X
BChamberlin is offline
Doorless Mirrors, again cstaup TJ Wrangler Technical Forum 15 06-04-2012 08:18 PM
side mirrors doorless tracer17 TJ Wrangler Technical Forum 52 07-10-2007 12:55 PM
Mirrors - Doorless MTDennis TJ Wrangler Technical Forum 9 03-10-2007 03:39 PM
Doorless...needs mirrors Jeepthing88 TJ Wrangler Technical Forum 10 07-09-2006 04:54 PM
Harley Mirrors for Doorless TJ BillArf TJ Wrangler Technical Forum 5 09-26-2004 12:55 PM
