Go Topless! - JeepForum.com
post #1 of 33 Old 06-02-2005, 12:28 PM Thread Starter
PDX_XJ
PDX_XJ's Avatar
Go Topless!
Alright - broke college student question of the day:
My TJ has a hard top and full steel doors. The top is coming off in two weeks when I move into my new place. Problem is, it rains almost daily here in Portland, OR. I know the cheapest option to deal with rain is to buy a pair of swim trunks and pull the drain plugs. What's the second cheapest?
Will a bikini do the trick if I leave the back seat out? Should I pony up the cash for a factory soft top? I've heard negative things about Bestop and other aftermarket tops, so what's the consensus?
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline
post #2 of 33 Old 06-02-2005, 12:32 PM
got4-Lo
bikini and duster is what i run all summer. and i leave it in the rain sometimes, its fine as longs as its not a down pour
stretched *** tj
got4-Lo is offline
post #3 of 33 Old 06-02-2005, 12:42 PM Thread Starter
PDX_XJ
PDX_XJ's Avatar
Hmm... dounpours are all we get here. The streets turn into rivers.
PDX_XJ is offline
post #4 of 33 Old 06-02-2005, 12:43 PM
highmeh
Hey PDX,
how about this?
http://cgi.ebay.com/ebaymotors/ws/eB...category=50456
2004 Jeep Wrangler 'X' I6 4.0L
Disconnected, 31" Tires, Plenty of Dents.
highmeh is offline
post #5 of 33 Old 06-02-2005, 12:45 PM
RockRunner85
Get a binki top, windjammer, and some soft doors. I don't have a windjammer or bikini top, but I do know that without the rear window in my soft top when its raining, the water will come in from the back and get ya wet. I do have the soft doors and there great. They let some water in through the seams but overall its great protection.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #6 of 33 Old 06-02-2005, 12:46 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
a safari top and a duster is all you need.
lj
ಠ_ಠ
LoneJeeper is offline
post #7 of 33 Old 06-02-2005, 01:20 PM
micfly83
I just take off my shirt and enjoy the shower
1994 Jeep Wrangler YJ, 2.5L High Output, High flow aluminum intake, 4.0L Throttle Body, 62mm TB Spacer, bored out intake manifold, 5spd, 3" suspension lift, 31" BFG A/Ts, Two 10,000lb tow hooks, DT3000s, Outland lightbar, 5 high powered offroad lights, Mapp Nerf Bars, 102" whip antenna, Midland CB, 6 speaker soundbar, Smallest leaf removed, Air restrictor removed, No trackbars, No swaybars, No A/C, Custom 32 song horn-
http://www.cardomain.com/memberpage/753987
micfly83 is offline
post #8 of 33 Old 06-02-2005, 01:54 PM
TXST8tj
TXST8tj's Avatar
cheapest solution would be the safari and duster. the doors are easy enough to take on and off. with the doors on and the safari on, you will be pretty safe from the elements. the duster will keep the back from getting too wet.
Patrick
TXST8tj is offline
post #9 of 33 Old 06-02-2005, 02:33 PM
Alec
door sourrouds anyone?
97 Green Sahara -
Powertrain envy sufferer - Softop tinkerer
Alec is offline
post #10 of 33 Old 06-02-2005, 02:40 PM
erickpl
erickpl's Avatar
x2 on what TXST8TJ said... That is my combination right now and with the doors on/up, it isn't too bad... you could even put some kind of prop under the duster to help water run off in the right direction (to the back) when you're not in it.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #11 of 33 Old 06-02-2005, 02:48 PM
JoonHoss
2011 JK Wrangler
definately try to find some door surrounds, they make a big difference.
Second, find a Cardboard box to stuff under your duster to help the water run off, they strech something fierce if left on their own.
Finally, throw a cuople of big yard waste size garbage bags (with tie handles) in your glove box or console, to cover your seats when you get caught in a downpour, or to keep your a$$ dry when you forget to cover them and have to drive home.
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #12 of 33 Old 06-02-2005, 03:03 PM
Suprmn54
i have the bikini and duster for my 97 TJ hardtop and full steel doors as well. The duster does catch some water in the middle of it if you let it sit in the rain...but other than that it covers nicely. The bikini gets you a little wet when youre driving when it's really coming down hard but when it's parked i un-velcro the flaps and hang them on top of the full door and it keeps everything dry. Hope this helps.
1997 Black TJ
2.5L Manual 4 Cyl.
Completely Stock
Suprmn54 is offline
post #13 of 33 Old 06-02-2005, 03:16 PM
RockPaws
RockPaws's Avatar
If your concerned about the rain while your not driving it. Why not get a cover. I've got the one from Jeep Covers Great cover, well made, very good tie downs, and can be used while towing. Best of all .. its made in the USA! and the price is right $109.95.
Mine was shipped the same day and received the next.. But then Im only 40 miles from them.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #14 of 33 Old 06-02-2005, 03:18 PM
IlliniJeeper
That's what I do. You wouldn't believe the looks you get hauling *** getting home during a notorious Chicago spur-o-the-moment thundershower. It's even better if you have the doors off and the wide tires spray you every time you take a corner!
'98 Jeep TJ Sport
IlliniJeeper is offline
post #15 of 33 Old 06-02-2005, 03:36 PM
frodare
Donít get the bikini top thinking it will keep you dry, it will not. It will certainly help a great deal but in the end I was very unhappy with it because I didnít want water on my radio and seats. But I feel in love with the bikini Ė duster set up and couldnít go to a full soft top. I ended up cutting the back off the old beat up soft top that came with the jeep when I bought it so that it acted like a bikini. I didnít have the windows for it anyway. I have been happy ever since, I really wish someone sold something like it. And just like some of the other have already said you will need the door surrounds or water will really pour in, they are kind of expensive though.
frodare is offline
Should I go Topless??? JeepinYahoo Wrangler General Discussion 21 10-15-2010 10:12 PM
Is the TJ ok topless day in and day out? chaznad TJ Wrangler Technical Forum 18 03-18-2009 05:26 AM
Went Topless.... Elwood TJ Wrangler Technical Forum 16 05-01-2007 10:50 AM
when she gets topless Ezrider_42101 YJ Wrangler Technical Forum 26 02-15-2006 09:09 PM
Going topless grinwa TJ Wrangler Technical Forum 7 04-17-2005 11:54 PM
