Go-Fer-It Offroad Flat Skid Plate - JeepForum.com
post #1 of 11 Old 12-04-2007, 11:29 AM Thread Starter
Lostj
Lostj's Avatar
http://www.goferitoffroad.com/products.htm
have any of you had experiences with this skid plate? would you recommend it? why/why not?
Thanks,
-Matt
00'TJ
74'CJ5 For Sale
Lostj is offline
post #2 of 11 Old 12-04-2007, 12:07 PM
Dogman
Dogman's Avatar
Dogman is offline
post #3 of 11 Old 12-04-2007, 12:09 PM
Dogman
Dogman's Avatar
Dogman is offline
post #4 of 11 Old 12-04-2007, 02:18 PM
Wrangler11
Wrangler11's Avatar
Do you have to have all 8 adj control arms?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #5 of 11 Old 12-04-2007, 03:49 PM
Dogman
Dogman's Avatar
No, just rear adjustable uppers to set the pinion angle for the SYE/CV.
John 3:17
Dogman is offline
post #6 of 11 Old 12-04-2007, 04:01 PM
lupinsea
lupinsea's Avatar
I'd recommend it because it is inexpensive (comparatively). The construction is crude, the finish is so-so, but it works pretty well. My has been perfectly fine for the 2+ years I've been using it. I ended up welding up the ends of the box steel to keep mud from getting inside but it's not critical.
Ordered from DC4WD.com for a good price.
But if you can get almost any other skid within $50 of the cost of this one then go with a different skid. Honestly, I'm fine with the Go-Fer-It. It's perfectly sturdy for general wheel'n. But other skids are better finished.
- Jay
lupinsea is offline
post #7 of 11 Old 12-04-2007, 08:33 PM
Wrangler11
Wrangler11's Avatar
Ah ok, just what is needed for the sye. Already got that. Maybe I'll look into one.
post #8 of 11 Old 12-04-2007, 08:52 PM
Chris @ GATR
Chris @ GATR's Avatar
If you can get them on the phone or get them to ever call you back.
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #9 of 11 Old 12-04-2007, 10:25 PM
Wrangler11
Wrangler11's Avatar
Not to high jack this. Do you guys think I'll have to make any changes beside the exhaust snice i already have the aa shift linkage bracket, sye and adj controls installed?
post #10 of 11 Old 12-05-2007, 11:55 AM
lupinsea
lupinsea's Avatar
Look at what you have in your sig, I think you're good to go. Keep in mind that doing a belly-up skid conversion is the equivalent of adding another 2" lift to whatever you now have in terms of your rear driveshaft. Most driveshafts can probably tolerate a 2" lift change. I'd still watch it but you should be ok.
- Jay
lupinsea is offline
post #11 of 11 Old 12-05-2007, 12:31 PM
Wrangler11
Wrangler11's Avatar
Good to know, I'll give Dave a call at Northridge and see what he says about the rear drive shaft.
Flat skid plate? elkfan2 TJ Wrangler Technical Forum 9 02-09-2010 10:37 PM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Flat TC skid plate fivedive69 TJ Wrangler Technical Forum 15 07-29-2008 09:37 AM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
Flat Transfercase skid plate & shifter relocation bracket sbninja TJ Wrangler Technical Forum 10 09-19-2005 04:40 PM
