GM V8 swap to jeeps 42RLE transmission - JeepForum.com
post #1 of 15 Old 01-03-2010, 04:30 PM Thread Starter
straycatboat
Can this be done with an adapter plate?
I would like to keep the Jeep trans if possible ... Cost reason
2004 tj X
straycatboat is offline
post #2 of 15 Old 01-03-2010, 05:03 PM
BlueFlame
BlueFlame's Avatar
Don't think so, but you can contact Novak and Advanced Adapters and ask.
BlueFlame is offline
post #3 of 15 Old 01-03-2010, 05:35 PM
ryan2022
that would be interesting......LS1!!
ryan2022 is offline
post #4 of 15 Old 01-03-2010, 05:43 PM
flatlander757
That's a terrible idea... the 42RLE isn't meant to hold tons of torque/power.
The 4 = 4 speed
2 = 2 out of 10 torque rating
R = rear wheel drive
E = electronically shifted(not sure if there is a designation for the L honestly)
FWIW The Dodge Rams and Jeep Grand Cherokees that had the 5.2L V8 and 5.9L in some cases had the stronger 46RH or 46RE. Depending on year one was hydraulically shifted and the other was electronically shifted.
If you're going to bother swapping in an LS1 don't half-*** it and try to keep the weak transmission. Best off just getting a 700R4 or a 4L60E(electronic version of the 700R4) if you can get it with the motor. You could get an adapter for the 700R4 to run the Jeep 231 then pretty easily... I haven't looked into it too much but I think in some applications it might just hook straight up.
Either way trans/t-case adapters are cheaper than bellhousing adapters.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #5 of 15 Old 01-03-2010, 05:56 PM
zband
zband's Avatar
I'm not too sure that the number two stands for a torque rating. I wouldn't be surprised if it could put up with the torque...
I have a 42RLE from 2003 and despite the fact that it shifts like ***, gets confused when to down shift and I would love to replace it with a manual, I cannot get the thing to fail after 150000 miles, 2 serious overheating events on the trail and yearly relentless abuse on the MI sand dunes every year.
zband is offline
post #6 of 15 Old 01-03-2010, 06:06 PM
flatlander757
That is indeed how Chrysler rates their auto transmissions.
The legendary torqueflite automatic transmission
The 42RE and the 46RH/46RE are all based on the same 727 transmission, except they all have an overdrive.
I'll be honest that I can't say what it is that makes the 46RH that much stronger than a 42RE, but that is how Chrysler rates their transmissions now.
Currently Jeepless.
post #7 of 15 Old 01-03-2010, 06:14 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a 42RLE wouldn't hold up behind a LS1 caliber V8. the 42RLE a crap transmission to begin with, save your money and use a better transmission.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 15 Old 01-03-2010, 06:47 PM
tjkj2002
2002 KJ Liberty
The 42RLE is not the same as the 42RE trans.The TJ get's the 42RLE trans(auto).The 42RLE is a upgraded version of the old A604 transmissions used in the 1st Caravan's.
And yes the torque rating for the 42RLE is 2 out of 10.
Recent Chrylser automatics usually have the basic format (Number of gears) (torque rating) (Transverse or Longitudinal) E(lectronic) so 41TE is a 4-speed, low-torque-capability, transverse-engine type transmission, while 62TE would be a six forward gears, higher capacity transmission for transverse mounted engines.
The 42RLE is weaker then the 45RFE/545RFE.
tjkj2002 is offline
post #9 of 15 Old 01-25-2010, 09:24 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
So for those of us with the 42rle that want to add more power to our motors, lets say a supercharger or a stroker, what are our options for a transmission that will take more abuse?
Will anything bolt up without adapters?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #10 of 15 Old 01-25-2010, 09:28 AM
Unlimited04
you can swap in an NV3550, or even an AW4...lots of work involved (manual trans PCM, lots of wiring, pedals, etc).
or you can rebuild the 42RLE with the TransGo shift kit, and a big cooler...and pray.
Useful Write-Ups:
Funny:
post #11 of 15 Old 01-25-2010, 09:31 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Why pedals?
Seems like after I'd spend the money to install a supercharger ~5k, then source an NV3550 or an aw4 (which isn't that great anyway) a PCM and do wiring ... I may as well throw in a 5.9 ....
post #12 of 15 Old 01-25-2010, 09:38 AM
Unlimited04
Why pedals?
brake & clutch pedals for manual (if you went NV3550)
and bingo...5.9L + 46RE + NV241J =
Useful Write-Ups:
Funny:
post #13 of 15 Old 01-25-2010, 09:50 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
So a local place is quoting me this for turn key just so I could have some figures....
5.9 & tranny swap - ~8k
Ripp Mods Super Charger ~5k
then when you factor in I can sell my motor & trans for hopefully 1K that drop the v8 swap to 7k.
And when you figure I need to add a new PCM & wiring for an aw4, plus the aw4 ... that goes up to about 6500.
So I'm thinking that for a difference of $500 I may as well do a 5.9 because really an Aw4 isn't anything so great to begin with.
Will a 241j bolt up to a 46re?
post #14 of 15 Old 01-25-2010, 10:04 AM
rideraa
Here is a link to 5.7 - LT-1 install ... he keep the small axles, which is not that good, it is a nice looking job though ...
Jeep Tj Build Off - Great Lakes 4x4. The largest offroad forum in the Midwest
"CHEAP HEAP" TJ, 4.0, 32rh, 231, built D44's, 37s etc.
"George 4man" CJ7, 304, 727, D300, C/O rear w/ stretch, built D44's (4 now) on pane :).
rideraa is offline
post #15 of 15 Old 01-25-2010, 10:10 AM
Unlimited04
I have no idea...but i believe the V8 ZJ guys do NP231 swaps, so if a NP231 will bolt up, a NV241J will. I think the ZJ's used longer input shafts on the NP231, so there is some shaft swap that needs to happen. Also, Dodge 2500's came with varying NV241's models with a long output shaft. I'm sure theres a 5.9L/46RH or 46RE + NV241/NV231 combo somehow. I don't know much about Dodge pickups...
So there's got to be a way to do it.
Dodge Ram Transfer Case Specifications
Useful Write-Ups:
Funny:
42RLE Auto Transmission (Regeared 3.73,4.56,now 4.88) JESSETHELJ TJ Wrangler Technical Forum 57 07-21-2011 01:32 PM
04 Auto - 42RLE - Transmission Cooler UnsanePyro TJ Wrangler Technical Forum 10 10-18-2010 06:29 PM
Looking for some feedback from drivers of the 42rle auto transmission Wif TJ Wrangler Technical Forum 24 04-23-2008 12:49 PM
42RLE transmission filter only sold by Jeep? zband TJ Wrangler Technical Forum 6 09-03-2006 02:45 PM
Where is the breather for a 42RLE transmission? Windsor TJ Wrangler Technical Forum 2 03-19-2006 10:03 PM
