glowing mini cats - Page 3 - JeepForum.com
post #31 of 34 Old 09-17-2013, 12:38 PM
Necko2529
Necko2529's Avatar
I had this happen to me on my ZJ after changing spark plugs, rotor cap and cables. I screwed up the firing worded and man were they (header and cat) getting red hot... It wasn't running fine like you say yours does but it sure heated up the garage in no time.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #32 of 34 Old 09-17-2013, 01:17 PM
05unlimit
Yeah I saw my buddy do that to a V10 ford. It got hot quick.......
My problem started when the OPDA began to fail. I was towing a trailer up the grade from LA to Vegas and the floorboards started to get hot. By the time I got over to the shoulder it looked like I had a ground effects neon kit installed. Replaced the OPDA (marked it and lined up the new one) and now the headers/mini cats glow under load. The Cats and exaust are flowing well, there aren't any codes and the milage is the usual 14.4 mpg. I've tried tweaking the OPDA position but it immediately throws a timing code if I rotate it even a fraction of a turn. Its been like this since march. I had pretty much given up trying to fix it until I ran across this old thread describing the exact same problem. Unfortunately, Roadkill hasn't been active in a few years so I can't ask him what ended up being the fix.
05unlimit is offline
post #33 of 34 Old 09-17-2013, 01:21 PM
JEK3
JEK3's Avatar
If you send him a PM, and his email address is still good, he may get the message. Can't hurt to try.
JEK3 is offline
post #34 of 34 Old 09-17-2013, 01:37 PM
05unlimit
One step ahead of you. I sent a pm this morning.
glow , glowing , mini cats , tj , wrangler , idle
Glowing exhaust manifold & high idle skinton TJ Wrangler Technical Forum 16 02-03-2012 12:46 PM
Blown Upper Mini-Cats clogged my main Cat Convertor = NO POWER socaldivemaster TJ Wrangler Technical Forum 23 08-29-2009 03:16 PM
Headers GLOWING....any suggestions welker YJ Wrangler Technical Forum 13 04-21-2009 02:38 PM
Glowing Headers and Cat SportTJ4x4 TJ Wrangler Technical Forum 10 09-26-2008 09:42 AM
Glowing Exhaust Manifold on 258 I6 Tshark299 YJ Wrangler Technical Forum 13 08-20-2004 03:13 PM
