getting rid of the Death WoBblEs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > getting rid of the Death WoBblEs
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 02-13-2015, 01:19 AM   #1
GOinPRO
my main goal is to rid Luceal of DEATH WOBBLES. once and for all. I have a 2000 jeep wrangler with a 3 in. lift on it. I believe that the reason I get the death wobbles is that I never loosened the Track bar when installing the lift.
Since I have had the wobbles so many times I'm guessing I have damaged most of the steering related components.
So, I plan on replacing the : pitman arm, drag link,track bar, tie rod, Sway bar links, and the lower control arms, steering stabalizer
Since a lot of lift kits have what I am trying to replace, I am Just going to upgrade the lift kit while im at it with a 4 - 5 in lift.
so... Here is my best guess:
skyJacker 4" lift kit: $518 ( control arms,sway bar links)
skyJacker track bar kit: $213 (track bar, steering stabilizer)
Heavy Duty Swedged Tie Rod Tube: $134
Tera flex heavy duty drag link $154
GOinPRO is offline   Reply With Quote Quick reply to this message
