Getting the best handling on a TJ - JeepForum.com
post #1 of 31 Old 09-21-2008, 01:54 PM Thread Starter
heyitsme
Whats some tricks to getting better handling on a Jeep? I've already got a skyjacker steering stabilizer. Would having 11.5-wide tires on 15x10 wheels have anything to do with it?
I drive +70 miles a day in it, mostly on 55mph highways, and I'm looking to make it easier to keep it between the ditches.
(Yeah, I know it's a Jeep thing, but i'm looking to improve it a little.)
heyitsme is offline
post #2 of 31 Old 09-21-2008, 02:23 PM
RKBA
What is it doing wrong, and what have you done so far?
2002 TJ SE
2006 LJ
2007 Rockwood Freedom 2280
RKBA is offline
post #3 of 31 Old 09-21-2008, 02:23 PM
never monday
if your Jeep is all over the road. Chances are there is a bad component or two in your suspension. The TJ has great handling stock and modified.
never monday is offline
post #4 of 31 Old 09-21-2008, 02:31 PM Thread Starter
heyitsme
It's not BAD bad, but just a little annoying after a little while of driving.
It's got a little slop to the steering, again, not A LOT but still enough to notice. It takes a fair amount of working it to keep it in a straight line.
heyitsme is offline
post #5 of 31 Old 09-21-2008, 02:33 PM
never monday
start by checking the tie rod ends. These parts wear out.
post #6 of 31 Old 09-21-2008, 02:38 PM
rubidriver
i have slop in the steering and mine is ALL over the road like bad, i also think it could be the tie rod ends because i get a slight wobble. ive checked it by having someone turn the sleering wheel with me watching but i couldnt tell if the parts are bad, how is the easiest way to tell???
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #7 of 31 Old 09-21-2008, 02:38 PM Thread Starter
heyitsme
It's only got 63k miles on it...is that still normal?
heyitsme is offline
post #8 of 31 Old 09-21-2008, 02:38 PM
hilton00
check for what? i feel the exact same way about my jeep, slop in steering and is kind of all over the road.
hilton00 is offline
post #9 of 31 Old 09-21-2008, 02:41 PM
mudb8
want it rite or rite now?
mudb8's Avatar
yep, and track bar bushings, ya know the drill
all can let em wander and feel like a steering problem
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #10 of 31 Old 09-21-2008, 03:00 PM Thread Starter
heyitsme
I'll have to check out the tie rod stuff, but my track bar is only about a month and a half old.
heyitsme is offline
post #11 of 31 Old 09-21-2008, 03:01 PM
mudb8
mudb8's Avatar
an important thing with a lift, even only 2" and over is the track bars need to be relocated to the oringinal stock angle, otherwise they tend to wander. the front sticks out the drivers side fender and the rear stick out the passenger side, the angle is increased wich takes less up or down movement via a rut,crown, or pothole in the road to jack the body around, we try to compensate for it by turning the wheel cause it feels like it wandering.
i view an adjustable track bar in the front and rear as fine for me with lifts up to 2.5, they don't fix the angle, they only center the axle. in rubidriver's case a track bar extension on the rear may take away the extra wandering as compared to stock. nth degree has a brace for the extension as well as relocation for the upper control arms.
thats a tj for ya. ya either get used to it or fix the geometry on lifted ones,
stock one that have excesive wandering is generally from a loose/worn joints, bushings and an ocasional worn out steering box bushing.
mudb8 is offline
post #12 of 31 Old 09-21-2008, 03:03 PM
never monday
you'll have to pull the tie rod ends out of the knuckles and wiggle the stud. If it's excessively easy to wobble. Replace it. Or for the cost of replacing then, do it as a preventative thing in the 50-75k area, lower with bigger tires.
post #13 of 31 Old 09-21-2008, 03:07 PM
mudb8
mudb8's Avatar
one thing I also noticed on the jks track bars is the steel insert in the ends is a tad larger than the factory bolt, in that case not drilling the frame bracket to fiit the proper size bolt can let the track bar move a little as if the bushing was bad, using the stock bolts you're depending on the bracket to s squeeze and hold the insert.
mudb8 is offline
post #14 of 31 Old 09-21-2008, 03:30 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
thats because its a Jeep.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #15 of 31 Old 09-21-2008, 03:37 PM Thread Starter
heyitsme
I've heard that already.
heyitsme is offline
Wind and handling. jeepguy79 TJ Wrangler Technical Forum 31 05-14-2008 08:52 PM
Handling Improvement, Can TJ=JK? fastRob TJ Wrangler Technical Forum 43 01-17-2008 04:53 PM
handling issues dpiontek YJ Wrangler Technical Forum 1 05-04-2007 03:17 PM
Very Poor Handling?? Jwinecoff00 TJ Wrangler Technical Forum 3 05-03-2007 07:07 PM
Handling in the wet Mike17112 TJ Wrangler Technical Forum 14 10-11-2002 09:28 AM
