Getting from 3.07's to 4.10's or better - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Getting from 3.07's to 4.10's or better
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 05-30-2012, 05:42 PM   #1
Spiderjohn
I'm getting ready to graduate from my 3.07's. I have a 2000 TJ Sport running on 31's. A local shop shop quoted me $2000 for a rebuild/regear and about another $300 if I add a limited slip in the rear. I've read all kinds of posts and opinions on Danas, 8.8s, Cherokee take offs. As a result I'm rather lost. I called a local salvage yard and found a 4cyl TJ that just rolled in. They're proud of their axles though. $900 plus for the front, $700 plus for the back. I am reasonably mechanical and am wondering if I should tackle the regear myself or shoot for a easier swap? Any thoughts?
Spiderjohn is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 05:49 PM   #2
Jason
Find cheaper replacements. You should be able to find them from a pick and pull for under $200.
Jason is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 05:51 PM   #3
Suleiute
You could probably talk to someone who's looking to regear from their 4.10's to 4.88's (ME) and would sell them to you for cheap.
Suleiute is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 06:01 PM   #4
1999TJRED85000
$2000? That sounds like a lot. It should be 4 to 6 hours labor + parts. Maybe $1300 to $1700? Make sure you get a specific list of what they are doing for the regear.
F U
1999TJRED85000 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 06:16 PM   #5
JBTJ
I would do the Dana 44 swap for the rear, and regear your front Dana 30. Make sure it's a manual transmission if you want 4.10. The auto's have 3.73
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 06:35 PM   #6
Bedwell
1984 CJ8
Any other shops in the area that do regear? $2000 bucks seems pretty steep to just go to 4.10s.
Bedwell is offline   Reply With Quote Quick reply to this message
Unread 05-30-2012, 07:42 PM   #7
cfmiller58
check out east coast gear and supply. you can get just about get an 8.8 and high pinion 30 for that price. that;s way too much. also check out pirate 4x4's classifieds, i find they have more axles there. dont forget craigslist, that's how i upgraded.
Black Jeep Society
The Build
cfmiller58 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2012, 06:15 AM   #8
Erik T.
I paid $1500 for my 8.8 with new disc brakes, 4.10 gears, and limited slip from ECGS. Than I paid $300 for a take off D30 with 4.10 gears(the guy was selling a set for $700 and I managed to get just the front from him). Which I built up before swapping under.
You shouldn't pay more than $1200 to regear front and rear axles, expect more for locker and limited slip(obviously).
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline   Reply With Quote Quick reply to this message
Unread 06-01-2012, 07:14 AM   #9
MGoBlue
The guy that owns the local Jeep parts shop will regear axles for $600 each! 2k is very high IMO. And those prices for D30, D35 are a little high too. Have you watched Craigslist? A straight swap is very easy. I'd say take it on.
http://boise.craigslist.org/pts/3036000741.html
Don't fear the regear!
MGoBlue is offline   Reply With Quote Quick reply to this message
Unread 06-01-2012, 07:48 AM   #10
BioTex
I tackled a regear for my first time with lots of help from the guys on the CJ forum. With the proper tools, and a set of "setup" bearings, you can do it yourself. It took me probably around twenty times of taking the gears in/out to get the pattern correct. But now that I have done it before, I could do it in an evening per side.
It would be helpful to ask around and find someone maybe from a local club that has the experience, and see if they will stop by and read the pattern for you before you button it up. I posted HQ pictures, and guys on the forum read them until we all agreed it was good to go.
I say go for it.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote Quick reply to this message
3.07 , 4.10 , differential , regearing
