GenRights stretch gas tank - JeepForum.com
post #1 of 9 Old 03-06-2007, 02:54 AM Thread Starter
Dans01TJ
I am looking at the COMP model tank and can't decide if the 14.5 gal capacity is going to be enough? I really like the 7" stretch but is the 5" stretch tank with 19.5 gallon capacity going to be really that much better? I just don't want regret getting the smaller tank at each refill time. Any advice on which to use?
I just need to know is the extra 2" stretch worth the loss of 5 gallons of gas?
Dans01TJ is offline
post #2 of 9 Old 03-06-2007, 06:44 AM
UCTJ
UCTJ's Avatar
Well are you going to be using your rig as a DD or more of a trail only rig? When the time comes that I can make mine a trail only rig and I do a stretch I think that the 14.5 would be more than enough...guess its how far you plan on driving at any one time.
UCTJ is offline
post #3 of 9 Old 03-06-2007, 10:30 AM
bluejeep2088
how much do you think it would cost to get a local shop to make a gas tank? i dont see it being anywhere near $800 but i also dont work in a metal shop.
I was also lookin at this tank buts it so expensive for it to just be a gas tank. Almost a grand, thats crazy.
99TJ, 3.5 RE,33x12.5 bfg mts, ford 8.8 and dana 30 with 4.56 gears, rhino lined tub, IPF head lights, AFE cold air intake, TB spacer, catch all floor mats, sound system to block out the loud *** tires, 2 piece hardtop, brown dog 1" mm lift
bluejeep2088 is offline
post #4 of 9 Old 03-06-2007, 11:06 AM
JerryC
You will need to comp cut your rear fenders for a 7" stretch. With the 5" you will be able to keep the back of your stock fenders in place.
Which do you want to do?
JerryC is offline
post #5 of 9 Old 03-06-2007, 04:49 PM Thread Starter
Dans01TJ
I already plan to use there Comp Cut rear fender guards and longer rocker guards as well. As for the price ($800) you also get a gas tank skid plate with that price so it's not as bad.
Dans01TJ is offline
post #6 of 9 Old 03-06-2007, 05:21 PM
al666
why not buy a fuel cell? i just got one from rci
al666 is offline
post #7 of 9 Old 03-06-2007, 05:25 PM
bluejeep2088
then you have no room inside your jeep, cause you have so much to to begin with lol
post #8 of 9 Old 03-07-2007, 02:11 PM
Dom45ACP
my 1999 came with the 14 gal tank, and I hate it. I wish every day I would have bought a Sahara instead of the Sport just for the 19 gal tank. The next year or a couple years later they put 19's in all. Grrrrrrrr.........
Dom45ACP is offline
post #9 of 9 Old 03-07-2007, 02:21 PM
Erik T.
Erik T.'s Avatar
-hugs his 19 gal fuel tank that lights up when he has ~4 or 5 gallons left-
Is it not possible to buy a 19 gal tank from a junked TJ and swap it in? Or does it require fabbing work?
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
Fuel Tank Options for stretch or more room JeepRocks86 TJ Wrangler Technical Forum 74 11-30-2015 01:02 AM
Gas tank for rear stretch E_ROCK Wrangler General Discussion 2 01-21-2011 03:25 PM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 07:44 PM
tj stretch q's slowsi TJ Wrangler Technical Forum 28 07-27-2009 11:15 PM
anyone tried the clayton stretch kit or a custom stretch setup bluejeep2088 TJ Wrangler Technical Forum 5 02-01-2007 08:04 PM
