Gen-right gas tank install problem - JeepForum.com
post #1 of 12 Old 08-02-2010, 09:24 PM Thread Starter
VikesTJman
Alright guys, we put in the new 19.5 Gen-right Crawler gas tank, and ran into a severe problem. Put 5 gallons in. Got her runnin, then down the road she died. Since then, we found a pinched line, fixed it, and now she will start after primin a few times, but won't stay running. All was well when starting the build, but sat for 7 months and can't put the finger on it. Modified the evap system, maybe that is the problem? I will get some pics of the set up with the evap if someone thinks that is it. Thanks for the help and looking into this.
‎"The Democracy will cease to exist when we take from those who are willing to work and give to those who are not." -Thomas Jefferson
My Jeep Build:
VikesTJman is offline
post #2 of 12 Old 08-02-2010, 09:55 PM
meatlord
Maximum Disaster
meatlord's Avatar
Did the same mod to mine 4 months ago, and the evap relocate. No issues thus far with codes/driveability.
By the way, how did the front Hi-Lines go? Shoot me some pics inside and outside of fenders.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #3 of 12 Old 08-02-2010, 11:23 PM
breckboarder55
Double check the fuel pump harness
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #4 of 12 Old 08-03-2010, 07:04 AM
Bennettj13
Did you bend the fuel float? That could be causing an improper reading. Did you make sure there wasn't anything in the tank, you might have clogged the fuel filter.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #5 of 12 Old 08-03-2010, 10:34 AM Thread Starter
VikesTJman
It runs and primes fine. Just after a minute of running, it chokes off like its getting no fuel. It's throwing the P0463 code. Looked it up and going off of that. The float is fine. The harness had a clip that was broke and we zip tied it together, so we were going to mess with that, see if maybe that was the issue, and the filter might still come into play after some more troubleshooting, it just could be so many things.
My Jeep Build:
post #6 of 12 Old 08-03-2010, 02:15 PM Thread Starter
VikesTJman
Called gen-right and they said there is a vacuum being caused inside the tank. Time to check for kinks or pinches in any of the lines.
My Jeep Build:
post #7 of 12 Old 08-06-2010, 04:31 PM Thread Starter
VikesTJman
Got ahold of the engineering dept. at genright. turns out i had the wrong tank, and there is a missing evap vacuum line on the tank i needed, and the pump hole is too small too. Ordered a new one for the right year and hopefully that will fix the problem.
My Jeep Build:
post #8 of 12 Old 08-06-2010, 04:35 PM
meatlord
Maximum Disaster
meatlord's Avatar
So much for having the lines switched, huh?
meatlord is offline
post #9 of 12 Old 08-06-2010, 04:39 PM Thread Starter
VikesTJman
Yea. Lucky i talked to the engineer. Unlucky it was a wrong tank.
My Jeep Build:
post #10 of 12 Old 08-06-2010, 06:14 PM
breckboarder55
That's inconvenient hope, they comped your shipping...
01 Honda S2000DD
post #11 of 12 Old 08-08-2010, 09:33 PM Thread Starter
VikesTJman
The other tank that was wrong was too shallow. Make sure you get the right model for the right year jeep you got with the gen-right tanks. Got a new one (the right one), got all lines hooked up and no leaks. Engine still dies. After testing the fuel pressure at the fuel rail, and the amperage to the pump, and pressure coming from the pump, all signs point to the pump gone bad. Gettin a new one tomorrow, and will follow up with results after testing.
My Jeep Build:
post #12 of 12 Old 08-09-2010, 06:42 PM Thread Starter
VikesTJman
The pump had gone out. Replaced it and still died. Pulled the assembly apart and found the rubber check valve on the bottom had carmelized and hardened. Removed the washer holding the check valve and the check valve out, now it runs like she used to. SSSHHEEEE'SSSSSS ALLLLIIIIIIIIIIIIIIIVVVEEEEEEEE!!!!!!!!!!!!
My Jeep Build:
gen-right , gas , fuel , tank
Gas tank install question.. drespecki YJ Wrangler Technical Forum 4 05-16-2010 10:05 PM
91 yj new gas tank install problem 97babyxj YJ Wrangler Technical Forum 7 08-24-2009 06:49 AM
Skid Row Gas tank Install SurfnSnow TJ Wrangler Technical Forum 4 07-05-2007 09:56 AM
Kilby tank install erickpl TJ Wrangler Technical Forum 4 05-24-2005 07:09 AM
