gearshift lever replacement - JeepForum.com
post #1 of 7 Old 12-06-2006, 09:40 AM Thread Starter
hnutz
I just bought a 97 tj with a 3 inch BL that I want to remove. The previous owner said the lever had been extended and that I would need to cut out a section and weld it back in place.
Would it be easier just to buy a new lever? Is it easy to install while I'm dropping the BL? Also, where would be a good place to get one?
Any thoughts on this?
hnutz is offline
post #2 of 7 Old 12-06-2006, 12:49 PM
BlueFlame
BlueFlame's Avatar
This would be a wonderful time to go with a Hurst or B&M short throw shifter.
Check Summit for great prices.
BlueFlame is offline
post #3 of 7 Old 12-06-2006, 12:51 PM
Jeepinty
I guess you mean the shifter.....and I assume you mean the transmission not the transfer case. I second the b&m or hurst short-throw.
Jeepinty is offline
post #4 of 7 Old 12-06-2006, 03:16 PM Thread Starter
hnutz
Thanks for the info,
Do you know if either of those shifters will work with a 1 in body lift? In case I end up replacing the 3" with a 1" bl.
hnutz is offline
post #5 of 7 Old 12-06-2006, 03:44 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
ditch the 3" and run the 1". They should work fine. My buddy has the NV3550 in his 66 bronco with the hurst shifter and a 3" BL. works great.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #6 of 7 Old 12-06-2006, 03:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Contrary to how a Hurst or B&M can improve the shifting smoothness and quality for, say, a Chevy or Ford where there is an external shift mechanism, neither will help make a TJ shift any easier. For a TJ, they only replace the lever, the shift mechanism itself is inside the transmission and doesn't get replaced. They might feel different because they are shorter and would give a slightly shorter throw, but that's it. For that reason, I'd just find a used TJ shifter out of a junkyard.
Jerry Bransford is offline
post #7 of 7 Old 12-06-2006, 05:06 PM
BlueFlame
BlueFlame's Avatar
Yep, works just fine with a body lift.
The shorter throw is worth it. Jerry is right (as always) it didn't make it shift any 'better' but it's sure nicer not rowing the shifter around as far.
Air from Defrost only - help with lever replacement gfs_tech TJ Wrangler Technical Forum 6 11-10-2009 08:57 PM
Turn Signal Lever Replacement yjcrawler YJ Wrangler Technical Forum 6 02-22-2008 08:48 PM
1991 YJ Multi-Function lever replacement nygiants57 YJ Wrangler Technical Forum 5 08-16-2007 11:08 AM
Turn Signal Lever Replacement Jeeples YJ Wrangler Technical Forum 11 03-07-2007 04:55 AM
Low Gearshift After Lift SuMeRiaN TJ Wrangler Technical Forum 10 08-06-2005 09:33 PM
