Gears - Front & rear ??? - JeepForum.com
post #1 of 3 Old 03-29-2003, 02:34 AM Thread Starter
pascal
My 1999 TJ 4.0L came with Dana44 rear and Dana30 front.
I think rear gears : 3.73 Am I right??
I want to change it to 4.10. That means to change gears in both axles rear and front???
And something else. Is 4.10 the same with 4.09...etc..
Any suggestions from where to order...Quadratec.com or Truckperformance.com....
George Andreou - CYPRUS
4.0L TJ 1999 2"Lift, K&N performance kit, Borla cat back, Ramsey 9000, Right Hand Drive, DANA44 4.10 gears, 32x11.50R15
pascal is offline
post #2 of 3 Old 03-29-2003, 04:08 AM
Grady
Grady's Avatar
gear ratio depends what you have, auto, stick. Wouldn't jumping up to a 4:56 be alittle better? If you do have 3:73s then 4:10s doesn't seem that much of a boost.......just an opinion.
Quadratec ships overseas but they can be a problem (past experience) if ANYTHING goes wrong. Don't know about the other company.
"Jeep... the most fun you
can have without having sex"
What doesn't kill you...
just hurts like hell.
USN JEEP HULL #11
'02 TJ
'04 Grand Cherokee
Grady is offline
post #3 of 3 Old 03-29-2003, 08:30 AM
igofshn
Locked @ both ends
igofshn's Avatar
Re: Gears - Front & rear ???
With the D44 you do get 3.73 gears. Jumping to 4.10 woud be a waste of money unless you have an automatic. There isn't much difference between 3.73 and 4.10. If you have the 5 speed I would go with 4.56.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
Gears should front = rear? wanabejeeper YJ Wrangler Technical Forum 9 09-12-2009 11:09 PM
Different Gears in front and rear 02gixxersix TJ Wrangler Technical Forum 8 07-27-2008 12:17 PM
JK Front and Rear Gears TheBrazilNut JK Wrangler Technical Forum 3 05-31-2007 11:08 AM
Different Rear/Front Gears Pipedrummer TJ Wrangler Technical Forum 12 02-15-2007 05:44 PM
HELP front and rear axles have different gears!!! pwhit TJ Wrangler Technical Forum 4 07-17-2003 01:05 PM
