Gears on 4 cyl - JeepForum.com
post #1 of 11 Old 02-06-2011, 04:02 PM Thread Starter
incatj
Gears on 4 cyl
Looking at a 1998 TJ 4 cyl that is running a 4" lift and 33" tires. It has 4.56 gears. I know 4.88 may be preferable, but would this setup be OK for a weekend cruiser around town and occasional highway use?
Also, the Jeep has 118,000 miles on it but appears to be in good shape. I know the 4.0 is considered bulletproof, but what kind of life should I expect out of the 4 cyl? And how expensive would it be to rebuild at some point?
Thanks so much.
incatj is offline
post #2 of 11 Old 02-06-2011, 04:05 PM
LilyBayXJ
The 4 cyl and just as reliable as the 4.0. It's just a de-stroked 4.0 block with 2 cyl removed from the middle. 4.56 gears will be fine.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #3 of 11 Old 02-06-2011, 04:08 PM
rdtj
ive put my 4cyl through hell and its still kicking strong as ever. in my opinion its a pretty bulletproof motor. mine only has about 120,000 on it but ive seen them with 200,000 and up
rdtj is offline
post #4 of 11 Old 02-06-2011, 04:14 PM Thread Starter
incatj
OK, that's great to hear. Thanks for the quick feedback. Assuming everything works as intended, do you see any reason why it couldn't be driven from El Paso to St Louis (about 1100 miles)? I am working in El Paso until the end of the month and will have to drive whatever I buy home ...
incatj is offline
post #5 of 11 Old 02-06-2011, 04:38 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Automatic or manual transmission?
Welcome to the forum...
Knuckelhead is offline
post #6 of 11 Old 02-06-2011, 04:42 PM
fifedawg
I am running the 4cyl couldn't be happier. JP magazine indicated that 300,000 is not unheard of. It's a KISS motor. (keep it simple stupid) and it runs great forever.
Life is what happens ... when you have something else planned.
fifedawg is offline
post #7 of 11 Old 02-06-2011, 04:46 PM Thread Starter
incatj
It's a manual transmission. I'm glad to hear people are happy with the 4. I owned a 2002 Sport a few years ago, sold it, and have missed the heck out of it since. I drive a Jetta on my commute but want something fun for summer and bad winter weather.
incatj is offline
post #8 of 11 Old 02-06-2011, 05:06 PM
silver97tj
silver97tj's Avatar
hi all
drove to florida 1200 one way several times, i dont see why not, other then gas mileage, seats are somewhat comfortable, road noise is probably going to be your common complant. just make sure you do thurough fliud and tuneup etc etc.......
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #9 of 11 Old 02-06-2011, 05:10 PM
rdtj
yea i dont see any problem driving it that far. like i said its a great motor and often underestimated
rdtj is offline
post #10 of 11 Old 02-06-2011, 05:14 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
4:56 gears and 33's won't be too bad. When I bought mine it had 4:10 gears and 33's and sucked, now it has 4:88 gears and 35's and it is a lot better. 4:88's and 33's would be the best combo, but I got a deal in the 35's and I can't complain too much.
xjfever is offline
post #11 of 11 Old 02-06-2011, 05:19 PM
Cavitation
imo 4.10s with the 4cyl and 33s is tolerable. You should be just fine with 4.56s.
Cavitation is offline
4 cyl , gears
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
