Gears(4.10 or 4.11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Gears(4.10 or 4.11
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 04-01-2002, 05:11 PM   #1
A-Teamer
Gears(4.10 or 4.11
Alright I know very little about gears and need me an edgamacation or atleast some answers. I have a 97tj sport, 4.0L,5spd,d30 front,d35 rear, with stock 3.07 gears. When I upgrade to 33" tires do I put in 4.10 or 4.11 R&P gears. Are they the same or is there a differnce? I was planning to hold off I this upgrade but now I am not sure. I can get the 4.10 gears off someone for around $100 and this shop said they would install for $700/w speedo gear, bearings and the whole 9yards. I was also thinking about a front arb locker but money would be tight(are lockers worth it or can I get away without)so I am not sure.
I have the stock 5 star 8"alum. wheels do I need to replace the for other wheels with different BSing or are these ok. Any suggestions would be welcome.(I just want to avoid doing things wrong or over at a later date)
Thanx
John "hanibal" Smith
"Roads? Where we're going we don't need roads."
A-Teamer is offline   Reply With Quote
Unread 04-01-2002, 05:30 PM   #2
Patton
The 4.10 and 4.11 ring gears are the same. Factory Dana is actually 4.106. Have the shop inspect the gears first if possible.
06 TJ X 4spd auto 3.73
4" pieced together lift
Patton is offline   Reply With Quote
Unread 04-15-2002, 10:06 AM   #3
JeepinAmerica.com
Yeah, Patton is right. I have 4.55 gears, but is someone asks, i'll just tell them 4.56
01 Flatfender Sahara.
1 ton axles, full width
Mods listed on my site
[url]www.JeepinAmerica.com[/url]
Tow vehicle: 01 F350 Dully, turbo deisel, crew cab,
JeepinAmerica.com is offline   Reply With Quote
Unread 04-15-2002, 12:51 PM   #4
Bob J
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by A-Teamer:
<strong> I was also thinking about a front arb locker but money would be tight(are lockers worth it or can I get away without)so I am not sure.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">If you're only gonna get one locker, put it in the rear, if you run in mud or on slippery surfaces, the locker would be worth it.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline   Reply With Quote
Unread 04-15-2002, 02:07 PM   #5
A-Teamer
Just curious as to the benefits of running it in the rear. I figureed you would want the traction in the front to help pull you through and steer. Most of my wheelin is in muddy conditions so I think it would be worth it, but the money issue and my lack of knowlege on lockers are holding me back. I have heard they can add stress to your axles(I have dana 35rear) and with the increase in tire size it may be too much?
Unread 04-15-2002, 03:31 PM   #6
JeepinAmerica.com
With a rear D35, you dont want to run tires larger than 33's with a locker in the rear. Both add stress to your axle, which can cause it to break.
Lockers are worth it, well worth it. A stock jeep, with 30s and lockers in front and rear WILL perform better in mud than a lifted jeep w/ 33s.
If you get one locker, put it in the rear. I have a detroit in my rear D44, and I love it!
Unread 04-16-2002, 11:16 AM   #7
bk_jeepin
I have watched many guys try to go up dump bump in moab with a locker in the rear and couldn't make it. Then a TJ with a air locker in the front walked right up it. I don't know how they do in the mud but on rocks I'd rather have the locker in the front. It just worked a lot better then in the rear. If you put the locewr in the front you will break so look into Warn's inner and outer axels. With those your 30 will be as strong as a 44 except for the ring and pinion.
It's a Jeep . . . . . . . . . . . . . . . . . . What else is there?
New owner of 81 waggy.
bk_jeepin is offline   Reply With Quote
Unread 04-16-2002, 01:49 PM   #8
99tjred
I was wondering if bkjeepin knew where I could find some used warn inner and outer axles.
99tjred is offline   Reply With Quote
Unread 04-16-2002, 02:24 PM   #9
bk_jeepin
I have the warn inner axels for a front D30 if your interested. Un fortunatly I don't have the outers but the inners are most likely to break before the outers. Anyways all who are interested just ask they retail for almost $400 and I'll sell them for $200. Great deal for anyone that wants them.
