gears - JeepForum.com
post #1 of 7 Old 08-04-2010, 06:57 PM Thread Starter
brockj
gears
i have a 2003 x model tj, and this maybe a stupid question, im pretty sure i have 3.07 gears. my question is, the gearing is the same front and rear correct? i am looking to buy new gears and want to make sure i need the same for the front and rear. also, how hard is it to change gears?
brockj is offline
post #2 of 7 Old 08-04-2010, 07:02 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Yes they have to both be the same.If you have to ask, your better off paying to have it done right.
GOLENJEEPTJ is offline
post #3 of 7 Old 08-04-2010, 07:13 PM
catITguy
Yes the front and rear are the same. I havent actually changed gears, but the process and reviews of people whose opinions I trust have me wondering if I should just bite the bullet and let a pro do it.
2000 Wrangler Sport, 4.0L auto
OME 2.5" Suspension Lift
1.25" JKS BL and 1" MML
33x12.5 GoodYear Wrangler Duratracs
catITguy is offline
post #4 of 7 Old 08-04-2010, 07:27 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Since you have an auto, you should have 3.73 gears.
Your current gear ratio is important to know so you know what parts are required when buying new gears.
If you have 3.73, you do not need new carriers to regear to a lower axle ratio such as 4.56 or 4.88.
If you somehow have 3.07, you'll need new carriers for both front and rear axles.
Wheelin98TJ is offline
post #5 of 7 Old 08-04-2010, 08:29 PM
chris142
It's a little involved. You dont just bolt them in and go. They have to be "set up" properly or they will burn up in 100 miles or less.
chris142 is offline
post #6 of 7 Old 08-04-2010, 09:26 PM
Eric06Rubi
Find some body you know that knows what they're donig to walk you thru it the first time. the education is absolutely priceless. There is also a small investment of some tools you will need to do the gear swap. Those of us who have done it also had to do it the first time. It's not real hard, just a little time consuming.
Good Luck
Eric
____________________________________________
ERIC
06 RUBICON+ SOME STUFF I MADE
It's all fun and games till some guy parks his Jeep on top of your Honda.
Eric06Rubi is offline
post #7 of 7 Old 08-04-2010, 09:34 PM
JOECUE123
hmmmm.... how much does it cost tools and all assuming that you do the labor yourself? Not including the beer you buy for your instructor?
JOECUE123 is offline
gears , ratio , front , rear , tj , wrangler
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
